... so looking at this spec sheet it looks like you might be able to EQ flat to around 109db using the same 90/75 CD horn they're using. I'm guesstimating I'd be down to 106db using the 16 ohm version.
http://www.bmspro.info/Curves.4540nd_hf-driver_curves.0.html
Thanks in advance for your measurements and ALL the info you've supplied thus far!
