Pyle PH-612, Throat Adapters, & B&C DE-250
AVS Forum member Augerpro is compiling a comprehensive data base of woofers, compression drivers, and waveguides:
http://sites.google.com/site/drivervault/Home
Among those studied is the E'Wave alternate Pyle PH-612 with B&C DE-250, and the measurements reveal a deep notch in the response curve just above 10 kHz. I ordered a pair of the Pyle waveguides to verify his findings.
It is unclear at this point exactly what throat adapter he is using. When I ordered the P-Audio PC-20 from the same source as him, they sent me the less expensive Selenium ADM-25s instead. Correspondence with Augerpro indicates that they also sent him those and not what he had ordered and thought he had received, so we are both awaiting resolution of this issue from the vendor.
Knowing from prior experience in this thread that, in detail, performance can vary with different drivers, throat adapters, and waveguides, I proceeded with the measurements using the throat adapters on hand, and here are the results, including with P-Audio PC-35, our standard thread-on D220Ti, and the bolt-on D220ti OMF with ADM-25 throat adapter. Note that the curves are unsmoothed and shown in 2X the normal resolution, each vertical division being 5 dB:
And here are the results sorted by Pyle PH-612 vs. the standard E'Wave JBL PT waveguide:
I ran out of room in the legend, apparently. D220Ti is Vio, Blue, and D220Ti OMF w/ADM-25 is Gry, Blk.
I confirm Augerpro's finding: the B&C DE-250 does not behave well on the Pyle PH-612 waveguide, but used with the JBL PT, it is quite good with the Selenium throat adapter, as we earlier found. The D220Ti works the same on either waveguide. With any bolt-on driver and either of these throat adapters, more work needs to be done to optimize the crossover in the region below 4 kHz.... :yes:
