lico
I'm running per the crossover schem with appropriate component values for the drivers. I have not tried it reversed. I need to do what Russell is doing and get into the measurement thing. My ears get confused with too many choices.
Same here. Wish I could measure the difference and generate some plots, maybe someday I will.
I have looked at the crossover in Spice for grins before, both ways. If you flip the polarity on the DE250, electrically it should cut the output in the 3.5 KHz range. Not sure if it matters much, but that is where the DE250 has been measured to show a "peak" per this post:
http://www.audiokarma.org/forums/showpost.php?p=2549189&postcount=4647
cross_1: Crossover circuit
cross_2: Summed LF + HF with drivers per spec
cross_3: Summed LF + HF, reverse the DE250 polarity
Now if I could get Zilch to measure the DE250 with reversed polarity then I could see what I have been listening to...
