Finished my first Econowave build. It is surpassing all my expectations. Here are the details:
1. Selenium 220/JBL WG, Selenium 12PW3 12" woofers. I selected these woofers for value, ability to play high with decent dispersion, higher Qts for punch in a sealed cabinet, high efficiency with low distortion. The plan is to crossover at 60Hz to my sub, so the limited Xmax is not a problem. These 12PW3s sound great up to 1.5Khz and are very inexpensive to boot.
2. 35" tall 2.8 cu ft cabinets with black gloss finish. Used india ink to blacken the plywood and wipe-on gloss poly. Filled heavily with 3lbs polyfill each.
3. High-efficiency crossover using specified parts and printed circuit boards from Zilch (thanks! -- made the job MUCH easier). Internal wiring is Monster Cable 16ga.
4. Sealed system aiming for a Qts (system) of 0.8 - 0.9. All seams fully caulked.
5. Zobel on the woofers to make the xover more effective.
Results:
1. Alas, no pictures yet. Finished in the evening and cannot seem to take good pictures with a black shiny cabinet and flash.
2. My main system consists of Magnepan MMGs, modded Xover and vertical raised orientation. The Econowave pair sound almost as smooth as the MMGs, but much more dynamic with plenty of punch. Instruments sound clear, bells are pristine, vocals very natural. The sweetspot is much wider than the MMGs -- the whole room is filled with consistent response, so unlike the MMGs. The soundstage is wider, just as deep, not as tall as the excellent MMGs. Surprisingly natural sound that is clear enough to reveal weaknesses in the audio chain -- my Denon sounds much better than an old Marantz receiver. After a hour of listening, I am finding distortion artifacts to be very low, no fatigue. The best part is the enjoyment at low volume levels -- the dynamic nature of the Econowave keeps me involved in the music even at "upstairs asleep" levels, something I could not do with my MMGs.
3. Agree that the best placement is cross-firing in front of the listening seat.
4. These puppies can get LOUD and still remain clear.
5. Ultimate neutrality is not its strong suit, but the other benefits are leaning me to replace my MMG mains with these DIY Ewaves.
The best $300 I have spent. Thanks to all of you.
