mcmurma
There are issues, specifically associated with the two drivers generating off-axis interference nulls, total cancellations, in fact, which impinge upon the dispersion pattern. In the normal vertical orientation with the drivers above or below each other, and employing waveguides having asymmetric directivity, the design may position these outside the vertical pattern, or near its edges to augment the forward lobe, but deployed horizontally the nulls occur within the normal listening window, as the angles are fairly narrow, in the range of +/- 20°. Round waveguides force a larger center-to-center distance, narrowing the lobe, as does the higher crossover frequency necessitated by smaller waveguide dimensions.
Scroll down to the end of this description to see the location of the null "eyes" about the axis at the 2kHz crossover frequency in the vertical polar map of this optimized 8" design using an asymmetric waveguide. They would be even closer using a round one:
http://www.eighteensound.com/staticContent/applications/kits/18Sound_kit8.pdf
Hmm, interesting point on the polar response Z. This kind of behavior had not even entered my mind. So I thought about it for a bit and came to the conclusion that while this is certainly an issue with the drivers on the same plane, angling the horn just a few degrees away from the midbass driver might tame a large part of this nastiness, and not be so far away that the midbass would become completely destabilized with regards to proper imaging. Just a thought... I'll think on it more.
And yea, I readily acknowledge that my desire is not strictly for a straight-up econo wave. But since I have become addicted to actives, and since I already have a spare x-over, and since I am planning to get a stereo setup in our main living room -- yes, you read that right, a stereo, NOT a home theater... even though the TV is in the room! The SAF is low with HT stuff. She cannot stand the thought of wires and boxes and amps that make her butt twitch during movies, but she is cool with a sub that delivers booty shaking bass for dancing. Go figure. Anyway, I'm just glad to have an excuse for making a new set of speakers
