OK, I re-measured using 8 Ohm non inductive resistors as dummy loads in place of drivers.
These are taken with DE250 on QSC on top of PE KD Trap box loaded with JBL 123A-1. Crossovers are standard EWave (30 Ohm comp) and 4Pi with additional fixed attenuation plus L-Pad and a notch filter to take the top down some.
Your measurements agree with my own and Jack's with respect to the DE250/QSC on the eWave highpass -- the green line. It is slightly overcompensated and the core frequency is too high, the latter being the primary reason the crossover has moved up to 2.2 kHz. Is this with R1 = 30 or 16 Ohms? Crank the high SPL up 4-5 dB and you'll be the same place as me, ~1.8 kHz.
See Geddes's horizontal polar for how we'd like it to be looking, his green line:
We're very close; we just have to move it lower by adjusting the core filter.
The 4-Pi highpass, the red line, is more overcompensated and underdamped. The culprit at 1.8 kHz is 123A-1. Wayne's lowpass knocks that down, orange, but not optimally, perhaps; the apparent flat response through the crossover region is coming from the underdamped HF driver making up the difference, an effective 4 dB of "boost" in a region below the recommended minimum crossover frequency for the DE250. Once the comp is tweaked, we'll not want that to remain. The fact that red is above blue there indicates the flat response is the result of a phase cancellation:
It'd be nice to get it playing well down there at 1.2 kHz (that's where Geddes uses it in Abbey, I believe), but the QSC is losing pattern control that low according to Brandon's polars, both in the horizontal:
And the vertical:
http://sites.google.com/site/drivervault/driver-measurements/horns-and-waveguides/qsc-pl-000446-gp
Much as we'd like the crossover to be lower, I'd prefer to stay with our 1.6 kHz target 'til we see where the vertical nodes come in; once that is known, we may be able to fine-tune a compromise, but the C/C distance is against us in accomplishing that with this waveguide.... :yes:
