jackgiff
Well-Known Member
Update on LR4 Xovers
While Zilch is attempting to figure out what is happening with the E'Wave Xovers and QSC waveguides/horns, I decided to put my B&C/QSC/PE Trapezoid cabinet pair to bed. With the LR4 crossover, I haven't found any of the extra nulls that have Zilch puzzled at this time. With the HF connected normally, a null happens directly in front of the baffle center. With the HF connected reverse, The vertical nulls appear almost equally above and below the baffle center. And looking at the plots for the Linkwitz Riley configuration, that is what should be expected, seems to me. Their may be other nulls there, but I can't find them, nor hear them. And I would really like to finish the pair of mesquite cabinets behind my equipment rack.
The cabinets were finished with another coat of Watco Danish oil, and two coats of Rub On Poly. The crossovers were then installed on the bolt on binding posts. The pictures show the Xovers mounted with and without the port tubes installed. One part (C3) needed an increase in value to 20 uF. The crossover schematic I used is shown as being revised on 11-27-2009. The speakers will be taken to my office at work, and used in a music system.
