Russellc
Addicted Member
Lot's of talk about better HF drivers, and some people are trying other ones. Some E'Waver's are enthralled by the B&C DE250, but just having finished a project using that driver, I think the BMS 4550 or 4552ND would be the better bet by far. Their mylar diaphragm sounds so smooth, and still goes to 20 KHz, although there is some breakup at the upper limit.
I have built three pairs using BMS, but none of them are EconoWave's. Why doesn't someone try doing an E'Wave using a pair of them? They are SWEEEET!
Edit: While the two mentioned BMS drivers are bolt mounted, the 4540ND is threaded, so will screw on to the JBL and Pyle waveguides recommended.
The Beyma is supposed to be the Bee's knees. 380 or something like that. Probably the next I'll use. I've only heard one BMS, ( 4550 I believe) and didnt care for it at all, likely not nearly enough sampling I'd imagine. didnt have nearly the clarity. Main reason I went with the DE 250.
Russellc
