cubby01
aka Buck
If anyone knows how to parse this back into an Excel table, feel free.
BMS INFO:
Model 4540ND 4544 4550 4552ND 4555
Throat Diameter 1" 1" 1" 1" 1.5"
Nominal Impedance 8 or 16 Ohm 8 or 16 Ohm 8 or 16 Ohm 8 or 16 Ohm 8 or 16 Ohm
Frequency Range (hz) 1.2khz-30khz 500hz-20khz 500hz-20khz 500hz-20khz 500hz-20khz
Recommended Crossover 1.9khz 1.2khz 800hz 1khz 1000hz
Power Capacity (AES) 60W 80W 80W 80W 80W
Magnet Material Neodymium Ceramic Ceramic Neodymium Ceramic
Voice Coil Diameter 1.5" 1.75" 1.75" 1.75" 1.75"
Overall Diameter 72mm 110mm 123mm 85mm 123mm
Depth 45mm 47mm 52mm 36mm 52mm
Net Weight .53kg 1.53kg 2.25kg .83kg 2.25kg
Mounting threaded 2 bolt/6mm 2 bolt/6mm 2 bolt/5mm 4 bolt/6mm
Easy enough to get into an Excel table here but I donno how to get it back into the thread...
