It's not the same waveguide, and I don't know the XO frequency, but there's a notch filter in there. Might play with that a bit.... :thmbsp:
http://www.jblproservice.com/pdf/EON Series/EON15 Diagram-Network Schematic.pdf
Well Andyman left here not to long ago, we listened to my KPM-10.0 wave version for
a while on a variety of music in a not to great setup, with a non Jack xover setup with
electronics that I'm sure leave a lot to be desired, that I was feeling pretty good about!
None of the horn/honkyness, none of the horn tunnel sound, but yet open and dynamic,
the bass at times in the outdoor canapy room was a bit excessive and overpowering to
where a minor tweak from the electronics was needed, but to me a good thing as I plan
to use mine with single ended tube amps and the extra bass is a plus! Andyman I believe
likes the midrange better on his Altecs and I probably agree but find it quite satisfying an
enjoyable with the wave as well plus the extra top and bottom on the KPM is a nice bonus
that I need/want.
So for first trial run they came through with flying colors as far as I'm concerned, I'm using
the xover from the parts express BR-1 kit speakers as I happen to have spares, they run a
xover that's not to far from Jacks, using the same woofer coil size but different caps and a
slightly higher xover point with no equalization an a zobel on the woofer as well. (OK not close)
(the BR-1 xover pads the tweeter about 6db and matches this woofer sensitivity quite good)
So I'm sure once I get the xover optimized they'll be even better, but for now pretty DAM good!
Cool Keg. I am still listening to mine using the xover that came with the Technics(sp) and am still amazed at how good they sound. Deep bass, crystal clear mids and highs. I am still debating whether or not to put them back on my Imps or do a full blown EWG with the proper xover. If you're not doing anything tomorrow, you should come over and we can do a shoot out. Cheers.
http://audiokarma.org/forums/showthread.php?p=1762207&#post1762207Which Selenium, the 210 or 220?
Probably really doesn't matter, does it?
I think it's time you got set up with measurement gear.Just bought a pair of ESS AMT 1C and will pick them up tomorrow. I really wanted the Heil tweet for my Imperials, but I think the woof and cab might make a good EWG....what do you think? Cheers.
Well, we'll see, AFTER you get the proper compensation running in E'Wave....Yah but that Heil tweeter sure does sound good, won't be getting rid of mine anytime soon.
Anyone was interested, maybe even Jack,
(the circuit board will definatly work nicely for the EWG circuit)
Yup, there's attenuation, but no HF compensation in the BR-1 circuit Kegger posted @ #929.The compensation circuit should make a huge difference as others have said. A non-generic low pass crossover would also help a great deal, I suspect.
