I suspect this leads to rethinking all the variant crossovers and not just this specific combo.
This combo, DE250 and the QSC waveguide, is unique. Add a particular woofer, a specific cabinet and driver spacing, and the requirement that the forward axis be steered at a small upward angle from the midpoint between the drivers, and an optimized design requires this level of effort.
Now if we can get a similar elegant high eff reasonable impedance version.... this thread would have an other ewave winner twin for the chip amp & tube boobs in DIY hifi....:sing:
This design is moderately high efficiency. You want higher, use KappaLite 3012HO and a sub. Look at the efficiencies of those two drivers in comparison to those we typically use here.
The impedance issue for tubes is easily handled with an L/R/C filter in front of the works.
Was this XO derived through simulation or working with the actual prototype?
Both. I provided the measurements in the actual cabinets for modeling in PCD. Pete took up the challenge over on Tech Talk forum and worked up the circuit. You can see us doing the standard eWave with DE250 earlier in that thread. I then built it and measured it, paying particular attention to the location of the forward null.
I think the problem is that changing the component(s) will shift the forward axis. I still wonder why not use a zobel to take down the spike a the top of the woofer's response, thereby leaving a smoother slope to sum and work with.
Try it in PCD and observe how the forward axis shifts.
Having been a DE250/QSC user for a while I can tell you that if you move around while listening, a few dB bump in the mid-range is moot, because the nulls loom nearby and the response in that region will vary. Nothing will change that given the x-o frequency/spacing.
And in spite of that, it sounds good.
We all need to maintain some perspective here; it's optimization we're doing, using a bigger flashlight. Without any of that, even, the fundamentals of EconoWave comprise a huge step up from conventional designs, constant directivity being the major one.... :yes:
560009/9750=57.4368
