I will be crossing the LCR to the sub at 80Hz but I do want that mid-upper bass punch that only larger drivers can provide.
I can squeeze in an 11" tall cabinet on the TV stand. I can then make the cabinet wider or deeper to maintain the same internal box volume. /QUOTE]
I wouldn't worry too much about getting a lot of punch out of the LCR since it is mostly dialog anyway. Set it to "small" since your height limitations pretty much makes it a small speaker anyway when stacking the drivers. So, the question becomes, how do we make the Delite 12 get small? Get the little brothers and sisters?
Alphalite 6A
http://www.parts-express.com/pdf/290-680s.pdf
and
B&C DE-10-8
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=294-600 (this pick saves ~$80 over the DE250 but needs to cross over higher (~2500Hz?) which isn't much of a problem for the 6.5" driver).
and a small (6x6?) bolt-on waveguide...I'm drawing a blank for a specific model.
That and a new crossover should make for a mean little eWave center channel or surround speaker.
Of course mounting 2 x 6" drivers in 11" will be a challenge. Overlap the flanges, trim the waveguide, and let the flanges extend to the edge of the 11" cabinet. It just might work. Or modify whatever the TV is on to make something bigger fit.:thmbsp:
My holiday weekend started a couple hours ago so please excuse any gaps in the 3-beer engineering process.
