There's not many 15" woofers that will play extended bass and mids well concurrently, and they all have limits.
2235H in 4430 is crossed at 1 kHz. Does that work? Yup, but it's a stretch.
416-8B is the woofer in Model 19, no? Does that work crossed at 1.2 kHz?
I have no experience with the Altec 411 Gordon mentions.
That certainly doesn't happen with either 2225H or 2235H:BTW, the response graphs I posted that go flat out to 4khz is a 15" woofer. It's very flat out to 1500hz at 45 degress off axis and out to 2500 hz at 30 degrees off axis.
What compensation are you using on the 811B? If it's the stock Altec crossover, the "magic" mids are artifically boosted, is what, and commonly characterized as "shouty."They sound fairly close to me, but Cindy says the E wave one is bassier and the supertweeter one is tweetier. I pretty much agree, but the Ewave seems a bit smoother with less extension than the tweetered Val, but loses a bit of magic in the mids; just not as engaging. Very close but not quite there.
If you like that, it's fine, but E'Wave is flat, and don't play that, nope.
If you want a reasonable comparison, remove the 811B and install a plywood flat with E'Wave mounted on it, closing the upper ports. Then, make a plywood cover for your port in the bottom with several ports in it. Close one or more of the ports to vary the box tuning. Measure it.
Your bottom box must be sealed to the bottom of the Val. Use closed-cell foam weatherstrip to accomplish that. The weight of the Val should make an adequate seal.
I'll repeat the same message I've posted many times: you can't do this stuff without measurement gear. Y'all in that group should pool some funds and get the Behringer RTA to share. A LHF member bought a used one on eBay for $125, with mic.... :yes:
It's unfortunate there's a big hole in the bottom of the Val, 'cause it could be flipped over and E'Wave just set on top.It's a cool experiment, though.
I s'pose the hole could be "undone" to try that....![]()
NOW yer cookin'!Going back to the original Val cab size (I lost the riser as cabinet volume when I rolled the cab), did cost some bass or at least "size" to the system; it's no longer the "bigger" sound. But these results are encouraging enough for me to pursue Zilch's suggestions of sealing the riser better, pulling the 811B and mounting the E-Wave on a sealed plate and experimenting with port sizes. More to follow this weekend.
Expand the knowledge base, Dave.I suppose I 've got to put my other projects aside and dig out my measurement gear. Nothing fancy, just a behringer mic, and art audio mic preamp for the phantom power, TrueRTA, Wallin jig, and speaker workshop.
I'd call that a pretty big leak, then.The PRs are not leaking, they are not there. It is just a 12" hole with a steel ring around the hole.
