Nice looking speakers you got there TS. I think I would of copied your disign if I would of seen them earlier.
cheers
I'd be SO tempted to cut in a 3012LF below there and run it in "0.5" mode.... :thmbsp:Nice looking speakers you got there TS. I think I would of copied your disign if I would of seen them earlier.![]()
panomaniac said:Sadly, Ed's speaker did not win or place. But I loved it. One of my favorites, for sure. That QSC waveguide and B&C driver combo is very good. I gave him high marks and talked his ear off about it. His woodwork is a beauty to behold, too.
Byrd,
Log in here:
http://audioroundtable.com/forum/index.php?t=thread&frm_id=33&
and post "may I have the 4Pi x-o pls...."
Wayne Parham will send it to you.
I am currently using that with additional attenuation for my DE250/QSC/JBL 123A-1/KDT combo. Like Russell, I like it for now. Not measuring perfectly, but very good.
The 4Pi speaker uses the same CD, other components are different. I use those at work. Very nice.
PS, the EWave HF compensation circuit is based on Wayne Parham's.
So how much will I have to tweak it and in what way to get it to work with a 2226H and the D220ti???
Of note: While TS's EconoWaves didn't win, they're getting very good press. For exmple, this from one of the judges:
http://www.diyaudio.com/forums/multi-way/169755-what-would-you-do-cabinet-7.html#post2243311
Sounds like you'll be running sub(s); augmenting the bass as I'm suggesting is more of a two-channel approach.... :yes:That would increase the price abit for me, since Im going to build 5-7 of them. Only have 2 down right now and the third this weekend, thats with the 2512's though.
I would not use a battery on a compression driver. Trust the terminal polarity or measure the system response to check the driver phasing....
skywave-rider posted:
I'd like to know more about the cabs...did I miss some posts?
I used Bass Box 6 Pro to design the box tuning for eWave Standard uisng the Dayton woofer in the trap cab, aiming for ~30 Hz. I then just stuck the Deluxe components in the same boxes, knowing that they would not make extended bass in that size enclosure without assist.Zilch or anyone:
I will be building the Deluxe but with tower: app 36Hx15.5Wx11D
this will give about 2.5 Cu Ft.
I understand (correctly, I hope) that the crossover will be fine whatever the box size.
I will not be using bass augmentation thru amplifier. I do not plan for now, to use sub woofers.
But I think your vent with the PE trap might have to be adjusted, how did you arrive at our vent size.? was it cut and try or did you use a vent modelling program. Any comments?
I will sketch up a side-view cut-away.
Any questions?
Thanks to all. Your on the top of the list, Zilch.
Where do I find information on this "Wayne" crossover?
Pi speakers. Wayne's site at Audioroundtable.com Get his crossover document while you're at it. He'll Email you it all upon request.
Russellc
I did, so I just build this crossover to a tee?
