Crossovers for DI-matched two-way speakers
Just a point of clarification:
The basic crossover topologies of most (all) of the speakers discussed in this thread are similar in terms of transfer function and of basic design. There are definitely differences, most of which are intended to get phase right to set the position of the forward lobe, balancing the variables of midwoofer and driver/horn reactance and driver position with crossover phase to ultimately set the position of the forward lobe and vertical nulls. But in general, we're talking about a single type of crossover, a two-way crossover that matches directivity in the crossover region and has top-octave compansation for (the mass-rolloff of) a compression driver on a CD horn.
There are differences as to the slope of the core splitter filters (1st-order, 2nd-order, 3rd-order) but even those are often chosen at least partially to set phase. The rolloff slope is often chosen to hit a design goal with respect to excursion, especially for the compression driver when used on a horn that will limit the excursion at high frequencies but that will unload at some low frequency limit, allowing the compression driver to move much further than it should, hence the need for rapid rolloff down low.
Still, in basic function, they all do the same thing (or should) and ultimately have the same transfer function, beyond the slope in the crossover region. The top-octave will always droop at a consistent 1st-order rate, simple physics, mass-rolloff has this slope. So a first-order conjugate is required. Some drivers may have extra breakup up high, so that can sort of make them a little hotter. Midwoofers may have breakup, making the low-pass need a notch filter or faster rolloff or something. Those are the kinds of details that cause the differences. But the basic design is the same.
When I first started making speakers like this, I experiemented with several crossover styles, several core splitters with different slopes and frequencies and several "auxiliary filters" such as notch filters and the like. I've used first-order filters through fourth-order filters and usually in new designs, I investigate all of them. In my crossover document, I show several basic crossovers, including a first-order using notch filters, another first-order with series/parallel attenuator/damping padding, a second-order, a third-order and mixed slope asymmentrical filters.
The first-order crossover shown in my crossover document (without a notch filter) is very much like what you guys call a "Deluxe" or 5 component crossover. The padding resistor values are much smaller in a circuit like that than they are in the higher-order crossovers, they have to be to get damping right for the transfer function needed. The crossover document also shows second and third-order filters, with component values appropriate for those kinds of networks. They allow more versatility in damping/peaking near crossover, but of course, require more components. In the end, you can read about each of those networks and what I thought about each of them from my little study/demonstration document, below. But also, ultimately, they all serve the same purpose and have the same basic topology, at least to my mind.
