Yes, of COURSE!
I want you to try to figure it out. :thmbsp:
You have enough information to do that.
I'll help you -- look at the PE chart.... :yes:
Get your horns and crossovers together, and bring out the woofer leads to give it a try sitting on top. You don't have to cut into them to hear how they're gonna work, and whether you like them.Any thoughts on bastardizing a pair of Klipsch KG4.5s? The horns will barely fit.
[Newman bein' BAD again....Not many Klipsch good enough to not be worth cutting up for EWGs.
Good luck, Evan, make them Kliphschirens sound good!
]BINGO!!anyways, i took a look at the chart & etc....and it looks like i should just double the inductance value and cut the cap value in half for 16 ohm woofer, right? tell me if i'm missing something. so L2 would be 3mh and c2 6 uf? thanks.
Yup, that'll work.We have one of our monthly audio meets out by ED\Squids place, he is bringing some JBL L-100's with the xover's disconnected and wires ran to the woofer through a port and I'm bringin the Wave tops with the xover in them to mate up with said JBL's, hope we can get them in the rotation for a while an see how they wave on out, should work!
Hey fellas, newman finally convinced me to jump on the bandwagon.
They are mint! I love cutting things up. The horns will barely fit.
Evan
6 uF is not a standard value, so you can use 5.6 uF, or, if you want to be spot on, a pair of 3 uF or a 2.7 and 3.3 uF in parallel.
I lke the last approach, because you can vary the value in 0.3 uF (5 %) increments just by changing one of the caps, i.e., get 2.4 and 3.0 uF also to tweak with.... :yes:
Nope, you've sussed it out; should be good to go, now.... :yes:time to order some stuff then...
do i need to change any other component values in the crossover? are only those two for the LF?
Gotta post yer E'Wave pics here to qualify as "Official" E'Waver :yes:do i get a EWaver badge now or when i finish?![]()
can you tell me how much cap value will change how much on xo point?
i think zilch told me about this path when i was fiddling around with 811/806 combo. just had to try and hear myself...guess it took me that long.
anyone with firsthand experience/comparison of 811 & this EWave?
414Z is 16-Ohms, no?
If so, it needs different lowpass values for the woofer.
If not, what Dave said.... :thmbsp:
Look at the PE chart:
http://www.partsexpress.com/resources/crossover-component-selection-guide.cfm
Yes. The stupid $9.90 E'Wave is better in many respects, constant directivity being a major one.
811 beats it when it comes to imaginary gonadotrophic effect, however.
['Course 511 beats them both in that respect....]
I can tell you it betters in many ways, the 511B which I always liked better than the 811B. The waveguide used here is more modern, more high fi, not as difuse as the 511B is. That said, it is exactly that quality that appeals to me with my A7s. Try it. See if you like it. Bear in mind that the ewave is, of course compensated for the JBL wave guide, and wouldnt be the same as the 811B. I compared using the crossover in my A7s, an eminence with dayton caps and compensation added. I just screwed a jbl 2425H on to the waveguide and hooked it up. No problem keeping up with 511B, even with compensation not designed for it.
Russellc
thanks for your input russellc.
i have high expectations for this plastic horn and the brazilian made driver.:thmbsp: i'm purely taking you guys' words for it.
How would it work with smaller woofers? like 10, 8, or even 6 inchers? has anyone tried it with speakers like AR 4x? or something like rogers monitor?
Several of us are working up "Mini-E'Wave" variants that'll fit in AR4x, or smaller, even, and others have built and are building the standard system with 10" drivers.... :thmbsp:
AR4x:you mean to be fit in the cab? so the horn will be cut out? that'd be awsome. i have another 4x that i haven't touched yet. if i can EWaverize 'em and seal the drivers up....hahaha i can imagine fooling my brother and friends.![]()
