juniorJBL
SUB 1500 :)
Whoops, didn't take that into account.
So maybe 150 pairs?
Probably closer to 1500+ pair.
So maybe 150 pairs?
Thousands is probably a stretch, but I wouldn't be surprised if hundreds and hundreds weren't the real and actual count.... :yes:Probably closer to 1500+ pair.
Wayne posted:
High-Fidelity Uniform-Directivity Loudspeakers Whitepaper
Zilch posted:
EconoWave is an internet Dreadnought-Juggernaut of substantial scope and scale...
:tresbon:
They are noted in the honorary E'Wave section. :yes:Everybody's E-Waves count, Steve...! :thmbsp:
mattyjman posted:
...anyone is attaching high pass filters to the bottom end of the woofers...?
...if I am integrating with a subwoofer?
...a B&C 10nw64 or a JBL 2206h. Would either of those work?
So, more questions:
From what I understand the B&C DE250 CD is a straight swap into the econo crossover, correct? any problem with using the pyle pro jbl knock off waveguide with a screw on adapter plate?
Can someone help me figure out how to augment the <95db crossover so I can supply my mid with a 70-80 hz 4th order crossover? That will make a nice transition into the subs I have planned, but the implementation is confusing. Hell, the schematic is confusing too. How do you read these things?![]()
On a separate note, for a center channel speaker, suppose I wanted to do a MTM configuration to keep it slim on height. Does this screw up the crossover and result and require a complete revamp, or would there be a simple fix to allow this. (Thinking maybe B&C DE250 flanked by 2 6.5 B&C mids, possibly 8's)
