Shadowdog
Alobar,
I have an 87 with the 2.9L /5 sp 4x4 and not too rusty I got for almost nothing 2 yrs ago and it will run for a bit and stop.
There isn't much to those old trucks and on mine, I think it's electrical also, but will change the fuel filter and check the pressure 1st.
I think mine only has 100 to 120K miles. Mine has an ignition module so that could be a cheap fix also.
I looked on Rock Auto and there is no ignition module listed for the 1998 and the only other cheap part is the camshaft
sensor and I read by the 90's the engine CPU's had gotten to be very reliable. The other thing to check is
the fuses and grounds.
IMHO I would keep that good ole reliable simple and cheap to fix truck, as for sure you will regret getting rid of it after!
I wish mine had the 3.0 as I think it's the best of the V6's in the Fords for longevity.
