91 Dodge Caravan V6 3.0, 231000 with normal maintenance... timing belt, water pump, hoses changed out every so often, trans drain and fill, new fuel pump just because. 1990 Chevy Corsica, 2.2 four, 301512 with normal maintenance... water pump, hoses changed out every so often, auto trans drain and fill, belt tensioner... has a 180 degree thermostat,(factory is 212) and after market fan control set just above thermostat, has a trans cooler I installed years ago, a valve job a couple years ago, replaced the fuel pump just because... runs fine. 2004 Honda Accord just breaking in with 31000, four cylinder, a garage queen.
