2017 Sansui Serial Number Database
I have sold this model:
G4700,820023055,cq.ab0nf
It now lives in Pueblo, CO with a guy who was really happy to get it.
And replaced it with this one:
G5700,859060272,cq.ab0nf
That 5700 is an absolutely amazing receiver with plenty of power. It was a good choice to move from the 4700 to the 5700.
441,014090732,russ25
Looking to get it back into daily use.
Hi russ25, welcome to AudioKarma Exclusively Sansui. Thanks for making your first post a serial number.
Your 441 was built on production line 01 in September 1974. It was the 732 unit off that line that month. Line 01 was also building 210s, AU-33s and TU-505s that month.
There are lots of folks here that can help get it up to snuff.
- Pete
@LBPete, @cnyel1967 => I have a smoking gun
In the PDF is an entry from 2018: TU217, 849050105, @cnyel1967
Now I found this week the following one:
TU-417,849050105,kleinanzeigen
@cnyel1967: do you still have the TU-217 and could you please check the number, if we have found a duplicate?
#View attachment 3572030
I don't think this is likely to be a duplicate. We have 25 TU-217s built in '79 on file but none built in May. Line 84 produced them in January and February. cnyel's is an outlier. There were 19 TU-217s built on line 84 in May of '78 including #0110. I don't want to cast any shade on @cnyel1967, because I've certainly made this kind of mistake, but I think it's much more likely that the 9 was actually an 8.
C-17,710090320,Reidy12,FB Sansui Vintage Australia [case for AU-999]
AU-999,231040336,Reidy12,FB Sansui Vintage Australia
@LBPete I believe and new category for the database.....it's the timber case for an AU-999 [s/n to come] did similar models of the era also have serial numbered cases?
Very cool! We knew that Sansui offered these accessory wood cases but I've never seen them identified with a model name sticker and serial number. I'll happily add the C-17 model to the database. Now I want to take the wood cover off my AU-999 to see if it has a serial number.
Some of the 5000 series receivers have the unit's serial number on the back edge of the wood cover but that had to have the cover factory installed. So those weren't an accessory.
771,236080075,DadsSansui
Your 771 was built on line 23 in August '76. It was the 75th unit off that line that month. Line 23 was also building the QSD-1, QRX-7001, AU-20000 and AU-11000 that month.
- Pete
Completed my harvest of leboncoin.fr. 333 Fresh serialz (attached). Very few duplicates, must be because of the language barrier. Fun fact: TU-S33L has been built in Japan and also assembled in France by Cablim SA. These have serial numbers starting with 543 on an orange label that is sometimes a bit garbled.
I came across a wrong model number in the database, DX-211HX-R should be D-X211HX-R. I think. The model D-550WR is not in the database. The receiver TA-1000L is listed as a tuner. And I've come across a true duplicate, an AU-7500 (allegro.pl) and a 350A (012120047):
I'll process that text file later. Lots of good information. I'll add a note to the TU-S33L model to indicate the alternate country of origin. We have 10 of them in the database and they are built on 5 different production lines.
The D-X211HX-R is completely wrong in the database. Both the model name and decade are off. I'll update both.
Looking at the TA-1000L. It's the top half of "stack" system. The ID label does say receiver so I'll make the change.
The AU-7500 and 350A are true duplicates. Line 01 was producing both models in December '72.
Thanks for finding all of this.
I put a note with the G-4700 that it was sold and will add the G-5700 to the August update.
- Pete
My harvest for WK33:
AU-alpha 707,607020381,catawiki.com,JDM,T-tag
C-77,860083918,catawiki.com
MR-6,609108042,catawiki.com
R-505,872121319,catawiki.com
D-77F,623012995,catawiki.com
A-40,860031333,marktplaats.nl
AU-111,26050169,marktplaats.nl
AU-417,219020037,marktplaats.nl
AU-517,228100935,marktplaats.nl
AU-D22,431121129,marktplaats.nl
TU-S33,812120477,marktplaats.nl
AU-D77X,624023305,marktplaats.nl
AU-X201,508010328,marktplaats.nl
B-1000,507111356,marktplaats.nl
B-1000,508120928,marktplaats.nl
D-X301i,328090813,marktplaats.nl
FR-D3,400021613,marktplaats.nl
P-2000,0902163330,marktplaats.nl
P-D30,513051779,marktplaats.nl
SIX,222110626,marktplaats.nl
D-1000W,627116661,marktplaats.nl
SE-1000,507071393,marktplaats.nl
TU-217,028072752,marktplaats.nl
My kv33 harvest:
310,822030118,kleinanzeigen
5050,026100219,kleinanzeigen
9090DB,817102419,kleinanzeigen
A-5,431076011,kleinanzeigen
AU-3900,026010468,kleinanzeigen
AU-X701,617076636,kleinanzeigen
CD-X317,15201000576,kleinanzeigen
CD-X510,306022649,kleinanzeigen
D-95M,741063459,kleinanzeigen
G-3000,017094314,kleinanzeigen
G-7000,858070898,kleinanzeigen
RX-5200L,SS-900800573,ebay-Italy https://www.ebay.de/itm/167716049533,12V Car Cassette Receiver
S-X700,527010264,kleinanzeigen
SE-9,831100239,kleinanzeigen
SR-525,325093126,kleinanzeigen
T-5,871020071,kleinanzeigen
TU-D55X,605114410,kleinanzeigen
TU-3900,836020320,kleinanzeigen
A 907XR was for sale for 400€ by a person who clearly didn't know what she was selling. Ad was gone within minutes - and no pic from the serial number. Same for the 9090DB with a requested price of 250€. Before driving it to the local "recycling centre" so throwing it away in the electric trash (=work to do) they tried to get rid of the amps on kleinanzeigen for whatever price as "only via pick-up, we won't send via postal service"...
G-901, 818010096, kertimjo
I think it's going to work again! Offsets and biases are good (with a 150 watt reptile lamp for a dim bulb test). The offset-reading multimeter was attached to each channel's output transistors' bussbar (schematic circles 13 and 14) as they were accessible from the topside. Infrared temp readings EVERYWHERE never got above 90 degrees F. Is it safe yet to plug it into the wall? More stories about all this work are yet to come ...
Please start a new thread in the Main Sansui Forum. There are a whole lot of folks there that can help you. This thread is for serial numbers and related discussions only.
- Pete
@peterott quote:
"A 907XR was for sale for 400€ by a person who clearly didn't know what she was selling. Ad was gone within minutes - and no pic from the serial number. Same for the 9090DB with a requested price of 250€. Before driving it to the local "recycling centre" so throwing it away in the electric trash (=work to do) they tried to get rid of the amps on kleinanzeigen for whatever price as "only via pick-up, we won't send via postal service"..."
It's good that they tried selling them before trashing them. They were probably surprised by how quickly they sold. Hopefully they went to someone that can repair them and put them back in service. The 9090DB probably just needs a cleaning and two resistors on the driver board. Either of those would be an epic score.
TU-S55X,624024445.cnyel1967
Thanks, got it! Your collection continues to grow.
- Pete
My harvest for WK34:
A-E550,436092244,catawiki.com
AU-555A,831090446,catawiki.com
AVP-701XR,601072455,catawiki.com
D-1000W,429011827,catawiki.com
SC-1300,249110848,catawiki.com
SR-525,326091055,catawiki.com
T-1000L,508051367,catawiki.com
A-40,609090705,marktplaats.nl
A-80,869091030,marktplaats.nl
AU-4900,026010013,marktplaats.nl
AU-555,830040928,marktplaats.nl
AU-D7,822100518,marktplaats.nl
AU-D9,821070041,marktplaats.nl
AU-D9,822100268,marktplaats.nl
AU-X501,438010545,marktplaats.nl
D-W9,684079129,marktplaats.nl
R-30,870060122,marktplaats.nl
RA-990,442100466,marktplaats.nl
SE-7,910040829,marktplaats.nl
SR-525,325081909,marktplaats.nl
TU-3900,025090121,marktplaats.nl
TU-3900,026080570,marktplaats.nl
TU-555,249120001,marktplaats.nl
TU-S33,872010752,marktplaats.nl
TU-S9,211030140,marktplaats.nl
TU-X301,617064984,marktplaats.nl
And a new model number, AVP-701XR:
And my harvest for 2021-H1 from allegro.pl's archive:
A-M7,572070066,allegro.pl
AU-3900,026030405,allegro.pl
AU-555A,831090565,allegro.pl
AU-6500,023030399,allegro.pl
AU-7500,833090335,allegro.pl
AU-D55X,644085748,allegro.pl
AU-X111,311050685,allegro.pl
AU-X117,125040163,allegro.pl
AU-X201,507080257,allegro.pl
AU-X201i,508050057,allegro.pl
AX-7,917092572,allegro.pl
B-2103,613012059,allegro.pl
CD-X301i,618070851,allegro.pl
CD-X301i,608071767,allegro.pl
CD-X317,15201000532,allegro.pl
D-350W,211332003144,allegro.pl
D-590R,635075032,allegro.pl
D-95M,231032735,allegro.pl
D-W10,644110224,allegro.pl
D-W11,348093923,allegro.pl
D-X111,639100687,allegro.pl
D-X117WR,14002000770,allegro.pl
D-X301i,328081214,allegro.pl
D-X317WR,632105096,allegro.pl
R-30,839075629,allegro.pl
R-5,851061681,allegro.pl
RA-990,582070092,allegro.pl
RA-990,582070833,allegro.pl
RZ-1000,519040309,allegro.pl
RZ-1500ii,2238000154,allegro.pl
RZ-3000,519040486,allegro.pl
RZ-3500,510120341,allegro.pl
RZ-3500,12003006326,allegro.pl
RZ-5500AVii,2241004367,allegro.pl
S-X700,507040448,allegro.pl
SC-1100,247120994,allegro.pl
SC-1110,248035323,allegro.pl
SC-3300,259091058,allegro.pl
SE-77,623101036,allegro.pl
SIX,223040400,allegro.pl
SR-222,316080560,allegro.pl
SR-222MKV,428080337,allegro.pl
T-1000L,508040396,allegro.pl
T-5,871020354,allegro.pl
T-60,840020012,allegro.pl
T-700,636087165,allegro.pl
T-80,849120129,allegro.pl
T-910,614099979,allegro.pl
TU-505,834030800,allegro.pl
TU-5900,026120636,allegro.pl
TU-5900,027032799,allegro.pl
TU-777,249020428,allegro.pl
TU-D33X,606072767,allegro.pl
AU-G33X,436054169,allegro.pl
TU-X301i,608065244,allegro.pl
TU-X501,608010689,allegro.pl
Now only 2021-H2 and the remainder of 2024 (and 2025) to go through...
kv34:
2000X,011100016,kleinanzeigen
3300,222051054,kleinanzeigen
9090,826060614,ebay.de
9090DB,816120145,kleinanzeigen
A-80,879093364,kleinanzeigen
A-910,464027519,kleinanzeigen
A-M90,574111319,kleinanzeigen
AU-717,218090902,kleinanzeigen
AU-X501,610072167,kleinanzeigen
AU-G11X,575105347,kleinanzeigen
B-2301L,627119693,kleinanzeigen,JDM 100V, T-tag
G-4500,829010197,kleinanzeigen
QRX-9001,237100180,kleinanzeigen
QRX-9001,237060560,kleinanzeigen
R-5,841086483,kleinanzeigen
S-X700,526110402,kleinanzeigen
SC-3110,597121405,kleinanzeigen
SP-X1U,9591,kleinanzeigen
SP-X1U,9592,kleinanzeigen
SP-X7000,98010496,kleinanzeigen
SP-X5U,5004,kleinanzeigen
SP-X5U,5026,kleinanzeigen
T-M90,664108163,kleinanzeigen
TU-X111,610108098,kleinanzeigen
TU-717,218090556,kleinanzeigen
8080db, 826110137, deltasonics
silver chassis
fuses f2657
bias transistors f2624
underneath 2619
resistors f2656
green FPC cables, no rivets
@PE9ZZ, I almost forgot about the leboncoin text file you posted. I just opened it. That's a lot of serial numbers! Also, that photo you posted of the ID plate for the AVP-701XR is extremely helpful. By far the most time consuming part of processing the serial numbers is chasing down confirmation of unknown models. Having a reference like that really helps. Thanks!
- Pete
