The voltages across the fuses were mention in posts 6-7 and 41-42 and then again in post 50.
Just to clarify what I am asking, I don't want the voltages ACROSS THE FUSES, I am asking about the voltage between wires going to the fuses from the transformer. See diagram below.
Post #50 is my post not yours.
Post #6 is my post where you did not do as I asked. Post #7 is where you measured from each fuse to GND... not from transformer lead to lead. Also, you did not say you measured ACV or DCV.
Post #41 is my post. #42 is saying that you got 0v same as before, but if you are referring to post #6 it is not what I asked.
OK, because you say that you can't trace the yellow and green wires, you can measure them at the fuse board.
Please measure the ACV from YEL arrow to YEL arrow.
Please measure the ACV from GRN arrow to chassis GND.
I don't think you did this before, but if you did please
If you get 0V for all three sets of wires, then you either have a problem on the primary side of the transformer or a bad transformer, but it takes so long to get answers from you that it will take another 5 days to get what we need to determine if it is really bad.
