Comments:
1. 0.1: Measuring the waveform from peak to next peak it is about 3.2 div. At 0.1msec/div x 3.2div = 0.32msec
2. ?: To convert time to frequency, use the equation f = 1/t. So, f = 1/(0.32msec) = 1/(0.32 x 10^-3) = 3,125 Hz
3. still at 1000 hertz: One of your settings is off because your scope shows it is 3,125 Hz
volt/div set at .1 probe set at 1x: Your sine wave covers about 1 vertical division. If your probe is set to 1X and volt/div is .1 volts/div, then your signal is 0.1V peak-peak. This needs to increase to at least 0.5V to 1V peak-peak.
