I cleaned the area with 99% alcohol, let it dry, then used a clean eraser rubbed untill not black anymore, re cleaned with 99% alcohol ..let dry added flux, heated down on copper trace. solder runs up to connector but doesnt stick to trace. Do i need more heat on copper trace?That is either copper or brass so it should be solderable, but you need to clean it well first.
- First, clean both the trace and the feed through with 99% Isopropyl alcohol and a Q-tip
- Next, try to clean both with a pencil eraser and see if the oxidation is removed. If not use a extra fine piece of sandpaper. (careful not to scrub too hard).
- Clean again with alcohol & Q-tip
- Apply solder flux to both areas
- Heat the joint and apply a SMALL amount of solder and let it flow between the joint
- Test again with DMM
- If good, then clean again with alcohol and Q-tip
Maybe there is a coating on the copper trace. Try to sand it just enough to scuff it up a bit with very fine sandpaper, clean, then try again. Yes, you might need more heat.Do i need more heat on copper trace?
I have 2000 grit paper. I'm using 360 c for Temp. Should l go higher?Maybe there is a coating on the copper trace. Try to sand it just enough to scuff it up a bit with very fine sandpaper, clean, then try again. Yes, you might need more heat.
My solder is 63/37 . I will try and get the silver conductive pasteI wonder if it is aluminum? Maybe you can use some conductive epoxy?
What kind of solder are you using (60/40, 63/37 flux core...) hopefully not lead free?
As far as I can tell, that's what it says to do. Then let it dry. Try not to get it too far down the trace so it won't interrupt the sliding piece.So I can just clean and sand a little over the solid trace and use the syringe to apply a line to the connector from trace.
I reversed it , 2275 pre out to 2385 main in, 2275 aux for music, speakers on 2385 main. volume up on 2275 no distortion right or leftFrom that test, it sounds like the 2385 Preamp is good and both of your speakers are good. Looks like your balance control repair worked.
Now you need to try the reverse, 2275 Pre-out to 2385 Main in.
