JE04 pin 3 to 2 = 75k pin 2 to 1 = 75 k
RE51 is not a resistor as per photoThanks. It looks like your board has a resistor, RE51, in the path. By your measurements, I think it is also 75k.
What is the resistor color code, and does it equal 75k (VIO-GRN-ORG)?
That is what is called a "Zero Ohm Resistor"... a wire that jumps across the board. It just continues the trace across the board.RE51 is not a resistor as per photo
Yes 0.1 ohmsSTEP 5:
I want to skip looking at the two amps QE01 and QE02 for now, but I would like to follow the signal path to the connector as it leaves the board.
- Black lead on CE13 (-), Red lead on JE07 Pin 1.
- The PCB labels it "L" but I think it is really the R channel.
- Do you have continuity, about 0 Ohms?
When i used pin 1 instead of 3 to test volume i got 79k at off and .09 ohm at fullThat is what is called a "Zero Ohm Resistor"... a wire that jumps across the board. It just continues the trace across the board.
So now I am a little confused. The parts list shows that the Volume Control, RE42 is:
Without resistor RE51, I would expect that when you measured the resistance from JE04 to CE01 (+) you would only see the resistance of the Volume Control.
From the PL it looks like it is either 20k or 250k depending on whether it is "B" or "V" (whatever that means), but you measured just across the volume control from JE04 Pin 2 to Pin 3 you got 75k Ohms??? The other thing that troubles me is that as you turn the Volume control, I would have thought it would go from 0 Ohms to 250k, but you measured "black on JE04 pin 3 red on CE01 + volume off 79k full at 140k". It seem like there is a 79k resistance somewhere on that path that adds to the volume control resistance???
Is there some part number screened or stamped on the volume control. I know it might be hard to see? I can just barely see it on your last photo.
Photo of volumeThat is what is called a "Zero Ohm Resistor"... a wire that jumps across the board. It just continues the trace across the board.
Wires removed pin 3 to 2 266 k 2to1 269k
JE07 pin 1 to JT01 pin 1 continuity, JE07 pin 2 to JT01 pin 2 no continuity, JE07 pin 3 to JT01 pin 3 no continuity. JT01 all 3 pins to solder joint continuity so board is fine, should i not have continuity to all 3 connections on JE07????STEP 6:
- Black lead on JE07 pin 1, Red lead on JT01 pin 1 on the PT00 Filter Amp board. Continuity?
- Black lead on JT03 pin 7, Red lead on PE00 JE05 pin 7. Continuity?
- Checking continuity on the PT00 board is a little more difficult because of all the resistors and transistors. We will leave it for later if needed.
Black on JT03 pin 7 red on JE05 pin 7 contiuitySTEP 6:
maybe that is the channel, there is definitely no contact at pin 3, so if that goes to a channel it is not working. How can i repair ?Looking at the schematic:
- JE07 pin 1 to JT01 pin 1 continuity - Schematic show that this is correct
- JE07 pin 2 to JT01 pin 2 no continuity - Schematic shows an open pin at JT01 pin 2 (board trace for JT01 pin 2 shows trace dead-ends.
- JE07 pin 3 to JT01 pin 3 no continuity - Schematic shows there should be connectivity, but this is for the other channel?
