what do you mean the voltage stays. Up or down?
I'm still seeing a lot of really old caps in here. Leaky coupling caps drive up the current load, so will a shorted cathode bypass cap on the 6L6. Likely pin 8 on both tubes will tie together, then go to a resistor to ground with a cap across it. If that cap is bad it screws things up.
Have to know where the screens (pin 4) are meant to go. They could go straight to the same B+ feed as the output transformer center tap. They could also be meant to feed from a lower voltage source. If they are supposed to get less voltage, the cathode resistor will not be the correct value to feed them from full B+.
