Based on this quote, why should they be considered?
Typical of
sealed-box speakers of similar size, the 3/5A has little or no low bass, but the design reinforced its lower register by a boost at around 160 Hz, giving the subjective impression that the speaker is more bass-rich.
[7][10][15] It has a gently rising frequency response above 5kHz,
[14] leading reviewers to notice the sound being a little bright at the treble registers, or that the speakers "reproduce the high- etc...
WTF???
Isn't bass of substantial quality and quantity among the desired attributes? (One more reason little speakers don't impress me.)
Absolutely agree with you. Not sure why his opinion on the not rare at all 3/5A speaker. Bass plays a major role in sound reproduction. If you are in a very small room within 5 feet of your speakers the LS3/5A shines but absolutely no bass you are correct. Although if placed on proper stands and anchored properly they will blow your mind....
Much depends on what you value in listening, how much room you have, how much volume you need to listen to, and how loud do you ultimately need a speaker to be given the first 3 issues, plus the type of music and vocals the LS3/5a was DESIGNED to do. The LS3/5a is designed as a small volume or area control or studio monitor primarily for vocals. It is optimized for the best sound quality of its day for a very small cabinet for relatively small spaces. It is designed to convey accurate and natural voice reproduction, and point out flaws in then tape and vinyl based recordings and broadcasts for the BBC. The bottom end is very much a compromise in giving the sense of bass reproduction without the physics-ly impossible ability to reproduce true bass and low bass with a small diameter and excursion 5 inch bextrene driver. The system designers (Dudley Harwood (of early Harbeth fame and designer of the polypropylene cone), Maurice Whatton, and R. Mills) plus a number of BBC techs, studio and sound people, added, primped, and adjusted the overall balance of the speaker repeatedly over about a year's R&D time to include the famous BBC dip and mid bass bump to give the speaker a slight bass boost to imply bass, and recess the balance ever so slightly to make the male vocals a bit less prominent. Female vocals are actually pretty sublime with the LS3/5a. The high end is actually a little hot (not tizzy) due to the protective tweeter grille and the need to be able to hear any problems over FM radio broadcasts and taped broadcasts done on Reel to Reel. Remember, this speaker was designed as an analytical tool and monitor for broadcast and studio use so was not meant to sound "hi-fi" or "pleasing" but rather sound accurate and natural, even though the frequency response is not ruler flat. Many many LS3/5a tweeters and crossover were burned out when someone inadvertently fast rewound or fast wound a RTR while the speaker was playing.
To the reasonably learned ears of the BBC personnel and professional sound, producers, and musicians of the day, it was a pretty darn good SMALL speaker - with known limits on how low, how loud, and how BIG it could sound. Within those limits, it works quite well. When people then, later, and today expand its use in the home environment, they will find a speaker with very good imaging ability, very good voice and music reproduction within its output and frequency limits, and an uncanny ability to essentially melt away and disappear from the setup, and involving the listener into a well recorded piece. However, if the recording or production is poor, the speaker is pretty ruthless about revealing that.
Yes, there are complaints about lack of power handling, limited frequency range, "slow" bextrene drivers (some of which was addressed with the 11 ohm revision from 1987 on), and aging effects on original LS3/5a woofers. But somehow the LS3/5a just does a lot of things well, just not everything. Even the BBC addressed that because the LS3 series is not what they base critical programme changes on, rather that belongs to the generally larger LS5 series, specifically the LS5/8, LS5/9, and the medium sized LS5/12, the last of the in house LS loudspeakers designed by the BBC. The last was built in conjunction with Harbeth and Dynaudio, and features tremendous power handling, output, and imaging in a relatively modest sized cabinet.
The LS5/8:
The LS5/9:
The LS5/12 next to a pair of LS3/5a's. The Dynaudio woofer is hugely vented to the rear and the Dynaudio Tweeter is grille protected.
