Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
looking at component space/clearance (right channel), making sure there is enough breathing room for the radial/taller components. after completing the second channel (left) there is a tight fit near the power switch, slight limitation.
unfortunately the parallel cap closest to the high heat parallel resistors takes the biggest thermal hit regardless how the pcb is mounted in the chassis.
so the heat shield thinking is only partially effective. either way the closest cap is getting cooked, even at system idle, from the inside and outside. film is more robust than electrolytic but there are limits either way.
no win scenario unless major redesign or even more aggressive wattage rating for the closest resistor(s).
direct pcb connection of output sockets probably not helping either when the amp channels are exercised.
upgraded the front end wiring (rectifier to power caps) using the previously mentioned 14ga and ditched the stock ~18ga stuff. ideally bumping up the 3+3 south of the power caps might tweak performance but we shall see/hear.
unfortunately the rail still sags even with low to medium output volume. at high output there is around 10v decrease per rail although more than enough reserve to feed the system. each rail at 120v mains are around 82.5v idle, so a total of 165v per channel
some idle reference numbers including r-ch +rail vs mains level. slowly reaching the end of posting this bryston project, consumed too many pages already.
final photo for the bryston 4b even though there are a few updates and enhancements on the to-do list. newer klh speakers getting a workout, sealed cabinets need wattage.
Shop used McIntosh SL-1 12" Powered Subwoofer; Walnut; SL1 with confidence at The Music Room. Expertly inspected, tested, certified, and backed by our Risk-Free Guarantee.
and some interior plate amp snapshots, inexpensive plate amp gasket was used. like the consistency and durability of something bought from walmart or amzn fresh from china.
interesting to note the lack of ground wire for high level input left channel, right channel only for mono input might have something to do with it. photo upper right corner.
significant internal brace although the complete lack of acoustic insulation or stuffing of any kind seems odd. vintage mcintosh speakers typically over stuffed arent they? perhaps only the early vintage cabinets.
screen covering the bass port, its fabric not metal. no indication any kind of stuffing was used in the box unless it was loose sheets easily removed or something.
numbers on the subwoofer assembly, two sets of terminals for the wire connections. one on either side of the basket.
after the fuse holder repair. soldered a piece of wire to hold the questionable electrode design together.
sub seems fully functional but definitely sounds hollow even with frequencies below the box-bark resonance (150-250hz). stuffing the cabinet would definitely help overall performance.
Hello Everyone, This is a review and detailed measurements of the Sony DVP-S7700, tested here as a CD stereo player and transport. This will be my second review of a DVD player, after the Denon DVD-3910. I will only review it as a CD player and Transport, like I usually perform. So don't...
So I picked up a pair of Visonik HiFi 'David 7000' monitors and a 'Sub 1' (passive sub), but will need help sourcing the correct foam for the mid/woofs. Also, one tweeter is blown. I'll have to find someone who can fix it or find a used one. Any tips on who to ask would be great. It's too bad the monitors don't have rubber surrounds like the sub does, which all look very similar to ADS drivers.
This is a cool set and I can't wait to bring it back to life. I'd be interested in any literature on the David 7000 and Sub 1, if anyone has some to share. Being an M&K fanboy, I've heard of...
