Carbsandcaps
When adjusting IF cans with 2 slugs how do you know which to adjust first? Is it just a case of getting the strongest signal by moving both?
Some schematics will have an arrow pointing up or down in the IF transformer symbol by the primary or secondary. Also Sam’s has a photo in the service literature on vintage gear that identifies adjustments with a callout. New stuff I don’t know.When adjusting IF cans with 2 slugs how do you know which to adjust first? Is it just a case of getting the strongest signal by moving both?
If the arrow points up on the schematic primary, the upper slug adjusts the primary. In my limited experience there is no consistency in schematics or upper always being the primary. But the Sam’s or manufacturers service literature will tell you.So there’s no universal answer as to which is the primary? Could be the upper or lower?
nope.So there’s no universal answer as to which is the primary?
yup.Could be the upper or lower?
For best results on AM, yes.It's more common for components around the IF cans or the caps inside the cans to fail than the coils themselves loosing tune.
You need to use a Sweep generator with a Scope to be able to see and adjust IF response.
I've lost count of all the radios ruined by someone trying to "Tweak" IF coils.
Source: Did RF, IF and Chroma alignment on tube type color TV's for a living. All went away once we went Solid State with Modules. For FM you need to massage the filters and coils to get a flat top and steep sides and most times it's pretty sketchy...
AK FM alignment discussion
Caps I have seen in IF cans of AM radios were ceramic, and those have good reliability in that setting.It's more common for components around the IF cans or the caps inside the cans to fail than the coils themselves loosing tune.
