MATT0404
Well-Known Member
Uh oh...afraid I didn't think about that. What alterations are required for use with 1590's?Saw that C2000 - Was listed with a set of L1590's - Wondering if it was altered for use with the 1590's
In lower corner of the attached jpg of the scematic the mod is listed. i also had the ads bullet from jdurbin which i cant find. As it does not not modify any of the 3 settings A,B,C, it wont effect your use for the 2030. Ive blown up the corner in the second pic. Wjen i modified mine, i tapes the parts and instruction inside for future use.Uh oh...afraid I didn't think about that. What alterations are required for use with 1590's?
Awesome! Thanks. Seller tells me this unit is unmodified. I will check it out once received.In lower corner of the attached jpg of the scematic the mod is listed. i also had the ads bullet from jdurbin which i cant find. As it does not not modify any of the 3 settings A,B,C, it wont effect your use for the 2030. Ive blown up the corner in the second pic. Wjen i modified mine, i tapes the parts and instruction inside for future use.View attachment 1412141 View attachment 1412142
Yes, Prob best to check anyway to see what you have. Unless they are the orig owner (and so know its not modified), and still yet i like to peek inside all my stuff anyway! Don't expect much action out of the "dynamic bass extender" led until your giving it bass, and volume level. Thought mine was out until i realized how it worked. Its more or less a peak level indicator when it starts trimming. (that's my understanding anyway) I did clean my volume control while i was in there. If you need tips on how to get at difficult controls feel free to PM. I bend the straws at a 90 to slide UNDER controls to shoot straight in (among other things). Prevents from having to disassemble a lot of stuff one might ordinarily think they have to.Awesome! Thanks. Seller tells me this unit is unmodified. I will check it out once received.
Ah, the next phase has started!Finally! Now to find an amp for the mids and highs. I will definitely continue using the Audire Otez on the woofers. Anyone have thoughts on a reasonably priced (as far under $1k as possible) amp for the mids and highs?
That is way cool!
Thanks, Joe! Hope all is well, my friend.I am absolutely thrilled for you Matt! Congratulations!
I definitely will, Glenn. Just want to get my wiring all sorted out first.Dayam!
Please post another video so we can get a taste of how this sounds!
Glenn
Thanks! You're welcome any time."Dayam" +1.
Beautiful gear and a beautiful Flexy. I might have to go crash on a couch in PA...!![]()
Very well could be the electrolytics, but cables are easy and I wanted to get a set that are the appropriate length for the new stand. They're also running very close to power cords now. The hum does seem to get a little better the further the C2000 is from the power amps. So, we'll see. Start with cables and go from there. I haven't opened the C2000 yet but will have a look soon. Given its age it would be good preventive maintenance to recap regardless.Hum isn't in the c2000? but getting into the cables to the amps or through the shielding of the crossover? Does the crossover need new 'lytics?
Isn't it amazing how much better the sound is when you don't need to dump a pile of watts into a passive crossover for the woofer? Each amp is in full control of the speakers attached.
I'll check back.
