ADS models, an impromptu rollcall
Soundmotor,
That makes sense... I'll try mounting the tweets 90 degrees from that used for the L810s and see if there is any difference. Thanks.
boyon00 said:
my L710's are 4 ohm and have 2 - 6" woofers.
Mine are the same 4 ohm with approximately 6" woofers. boyon00 do yours have foam or rubber surrounds?
cubdog
The 710's have 7" woofers in them. The early ones had foam and later ones had rubber. Probably by the time they were ADS not aDs they switched to rubber. In the ADS Line Pecking Order thread soundmoter gives the reason why earlier speakers had foam. Something to the effect that the rubber surround manufacturer didn't have that size in rubber. Richard So rebuilt the drivers in my 1975 vintage aDs 710's with rubber surrounds and still has some in stock the last time I communicated with him. :yes:
Well my cone diameter is 5". To the outer edge of the basket is 6 3/4". How does that translate to 7"?
cubdog
Sorry, you are correct soundmotor. What I mean to write is that the eight inch woofers in the L810s are really not eight... if measured, they seem like something betweek six and seven inches. :screwy: No matter, the series I versions seem to make reasonable bass as is... :thmbsp:
soundmotor said:
Careful.........
:nono:
:D
Did you get a pair? If so what do you think of them?
Here's the specs:
48-20,000 hz +- 3db
6 ohms nominal, 4 ohms minimum
92 db spl at 1 meter with 1 watt
1" dome tweeter
7" Stifflite driver
100 watts max
17.5x11.25x7
16 lbs
Thanks for the specs. I picked up a pair about a week ago, and I'm very impressed.
They're obviously lacking a bit in bass, but impressively efficient, crystal clear, and tight as a drum.
They took over in the home office/computer room for my EPI 100s while I recap, refoam (I put a drill through a new woofer foam when I re-capped one), and install 5-way binding posts, then break in the new caps. I'm not sure the EPIs will make it back in now.
I'm on the lookout for a pair for my kids room. Then I'll have backup tweets and drivers for my 710's if ever needed.
Updated list-
ADS CM5 (2 way) (5 1/4" woofer) (plasti-crete housing)
ADS CM6 (2 way) (6 1/2" woofer) (plasti-crete housing)
ADS CM7 (3 way) (7" woofer) (plasti-crete housing)
ADS SAT5 (2 way) (5 1/4" woofer)
ADS SAT6 (2 way) (6 1/2" woofer)
ADS SAT7 (3 way) (7" woofer)
ADS B7 (2 way) ( 7" woofer)
ADS B8 (2 way) ( 8" woofer)
ADS BC8 (3 way) ( 2x tweeters, 8" woofer) (Broadcast model c. 1978, looks like L730 from outside)
ADS L7e (2 way) ( 7" woofer)
ADS L8e (2 way) ( 8" woofer)
ADS L9e (3 way) ( 8" woofer)
ADS L10 (2 way) ( 7" woofer) 6 ohms
ADS L200
ADS L300c
ADS L200cc
ADS L200e
ADS Delta Lab L1 (L200 w/ internal high-pass for nearfield, high-output monitoring)
ADS 2001 (active "L200" type pre-77)
ADS 2002 (active "L200" type pre-84)
ADS AW4 (1st plastic housing L200e for outside use) (cabinet shape similar to 2001)
ADS L210 (last version of L200e)
ADS L300, L300c, L300cc, L300e
ADS L310 (last version of L300e)
ADS L400
ADS L400 version 2 (smaller cabinet) (7" woofer)
ADS L400e
ADS L420 (2 way, 2 driver) (7" woofer)
ADS L470, L470/2 (2 way, 2 driver) (7" woofer)
ADS L500
ADS L520 (2 way, 2 driver) (8" woofer) 8 ohms
ADS L570 (2 way, 2 driver) (8" woofer) 8 ohms
ADS L570/2 (2 way, 2 driver) (8" woofer) 8 ohms
ADS L620 (2 way, 2 driver) (10" woofer)
ADS L630 (3 way, 3 driver) (10" woofer) 8 ohms
ADS 700
ADS L700 (2 way, 3 driver) 4 ohms
ADS L710-A (3 way, 4 driver) (7" woofers) 4 ohms
ADS L710 (3 way, 4 driver) (7" woofers) 6 ohms
ADS L730 (3 way, 3 driver) (10" woofer?)
ADS L780
ADS L780/2 (8" woofer)
ADS L810/A (4 ohm)
ADS L810 (3 way, 4 driver) (8" woofers) 6 ohm
ADS L880, 880/2 (3 way, 3 driver) (10" woofer) 8 ohms
ADS L910 (3 way, 4 driver) (staggered 10" woofers) (bi-ampable, many used Pioneer XO)
ADS L980
ADS L980/2 (bi-ampable w/ modified C2000 crossover)
ADS L1230 (3 way, 4 driver) (8" woofer) (bi-ampable w/ C2000 crossover)
ADS L1530 (3 way, 4 driver) (10" woofer?) (bi-ampable w/ C2000 crossover)
ADS L2030 (3 way w/ line array mode, 7 driver) (14" woofer) (bi-ampable w/ C2000 crossover)
ADS PB1500 (subwoofer- utilized a C1500 crossover)
ADS PB1500 + 2, L400 (small versions) = SUBSAT2300 (also came w/ F400 stands)
ADS L690 (2 way, 2 driver) (8" woofer)
ADS L990 (3 way, 3 driver) (10" woofer)
ADS L1090 (3 way, 4 driver) (7" woofer)
ADS L1090/2 (3 way, 4 driver) (7" woofer)
L1290 (3 way, 4 driver) (8" woofer) (bi-ampable w/ modified C2000 crossover)
ADS L1290/2 (3 way, 4 driver) (8" woofer) (bi-ampable w/ modified C2000 crossover)
L1590 (3 way, 4 driver) (10" woofer) (bi-ampable w/ modified C2000 crossover)
ADS L1590/2 (3 way, 4 driver) (10" woofer) (bi-ampable w/ modified C2000 crossover)
ADS M9 (3 way, 3 driver) (8" woofer)
ADS M9/90 (3 way, 3 driver) (8" woofer)
ADS M12 (3 way, 4 driver) (8" woofer)
ADS M12/90 (3 way, 4 driver) (8" woofer)
ADS M15 (3 way, 4 driver) (10" woofer)
ADS M15/90 (3 way, 4 driver) (10" woofer)
ADS M20 (3 way, 4 driver) (dual 8" bandpass)
ADS M30 (3 way, 4 driver) (dual 10" bandpass)
ADS C300i (2 way inwall) (5 1/4" woofer)
ADS C300is (2 way inwall) (5 1/4" woofer)
ADS C400i (2 way inwall) (6 1/2" woofer)
ADS C400is (2 way inwall) (6 1/2" woofer)
ADS 750il (3 way inwall) (7" woofer)
ADS SW2 (10" passive in-floor subwoofer)
ADS SW4 (10" passive subwoofer)
ADS SW5 (12" active woofer)
ADS SUB6 (6 1/2" passive subwoofer)
ADS SUBSAT2 (L200e + SUB6)
ADS SUBSAT3 (L300e + SUB6)
ADS SUB10 (10" active bandpass subwoofer)
ADS SUB12 (12" active bandpass subwoofer)
ADS MS1
ADS MS2
ADS MS3
ADS HT400LCR
The ADS models listed below were/are rumored to exist, but after talking with a few members here, these are very well most likely non-existant models. But for the sake of it all, has anyone ever own one of these models listed below, or seen one of 'em, and want to say otherwise? Please let me know. But for now, I'm keeping them off the official list.
The rumored models-
ADS L600, with supposed 7" woofer
ADS 800, supposed 2 or 3 way, supposed 3 or 4 driver
ADS L1430, supposed 3 way, 4 driver
Duffinator said:
Nice work TDH. :thmbsp:
Awww, shucks- I'm just the messenger, my friend. All the worthy thanks are due to you, Dingus and Soundmotor here. You guys have enabled me, empowered me with all the info. And I still got more to go... But thanks for the support! :thmbsp: :thmbsp: :thmbsp:
