ADS models, an impromptu rollcall
Great list you three have generated, but my 810s are still missing. There is no L in the model number on the back of these 4-ohm speakers with push-in wire terminals.
It sure would be nice to expand this list to add columns with the model numbers of the drivers and production dates if at all known. I know the information would be coming from the members with and without replacement drivers in their speakers so maybe if this is done a note could be added if the drivers are not originals. Here is what I have.
My 810s have: 206-0117 Tweeters (replacements)
206-0211 and 206-0212 Midrange (replacements)
206-0317 Woofers 2 per cabinet (originals)
My L990s have: 206-0117 Tweeters (originals
206-0217 Midrange (originals)
I have not pulled a woofer yet as I have only had they a few weeks and the drivers are held in with double sided tape gaskets that almost require cabinet damage when removing drivers. So it may be a while. Production dates or purchase dates are unknown.
It sure would be nice to expand this list to add columns with the model numbers of the drivers and production dates if at all known...
I'll add your 810s right now, my friend. As for the driver info, great idea. Let's see if we get any other driver #s from members and then maybe consider adding them to the list, or possibly a second, driver-reference-specific list.
If you have a nice datasheet program, please feel free to make a spredsheet with this info. I don't have such a program on my Mac.
I also will add your L990s as they are not on the list either.
Are the L990s a three-way, three driver? Three way, 4-driver?
Any pics of these beauties?
Thank you for the info- it helps greatly here in forming this list. :thmbsp:
Updated list-
ADS CM5 (2 way) (5 1/4" woofer) (plasti-crete housing)
ADS CM6 (2 way) (6 1/2" woofer) (plasti-crete housing)
ADS CM7 (3 way) (7" woofer) (plasti-crete housing)
ADS SAT5 (2 way) (5 1/4" woofer)
ADS SAT6 (2 way) (6 1/2" woofer)
ADS SAT7 (3 way) (7" woofer)
ADS B7 (2 way) ( 7" woofer)
ADS B8 (2 way) ( 8" woofer)
ADS BC8 (3 way) ( 2x tweeters, 8" woofer) (Broadcast model c. 1978, looks like L730 from outside)
ADS L7e (2 way) ( 7" woofer)
ADS L8e (2 way) ( 8" woofer)
ADS L9e (3 way) ( 8" woofer)
ADS L10 (2 way) ( 7" woofer) 6 ohms
ADS L200
ADS L300c
ADS L200cc
ADS L200e
ADS Delta Lab L1 (L200 w/ internal high-pass for nearfield, high-output monitoring)
ADS 2001 (active "L200" type pre-77)
ADS 2002 (active "L200" type pre-84)
ADS AW4 (1st plastic housing L200e for outside use) (cabinet shape similar to 2001)
ADS L210 (last version of L200e)
ADS L300, L300c, L300cc, L300e
ADS L310 (last version of L300e)
ADS L400
ADS L400 version 2 (smaller cabinet) (7" woofer)
ADS L400e
ADS L420 (2 way, 2 driver) (7" woofer)
ADS L470, L470/2 (2 way, 2 driver) (7" woofer)
ADS L500
ADS L520 (2 way, 2 driver) (8" woofer) 8 ohms
ADS L570 (2 way, 2 driver) (8" woofer) 8 ohms
ADS L570/2 (2 way, 2 driver) (8" woofer) 8 ohms
ADS L620 (2 way, 2 driver) (10" woofer)
ADS L630 (3 way, 3 driver) (10" woofer) 8 ohms
ADS 700
ADS L700 (2 way, 3 driver) 4 ohms
ADS L710-A (3 way, 4 driver) (7" woofers) 4 ohms
ADS L710 (3 way, 4 driver) (7" woofers) 6 ohms
ADS L730 (3 way, 3 driver) (10" woofer?)
ADS L780
ADS L780/2 (8" woofer)
ADS 810 (n "L") (3-way, 4-driver) (4 ohm)
ADS L810/A (4 ohm)
ADS L810 (3 way, 4 driver) (8" woofers) 6 ohm
ADS L880, 880/2 (3 way, 3 driver) (10" woofer) 8 ohms
ADS L910 (3 way, 4 driver) (staggered 10" woofers) (bi-ampable, many used Pioneer XO)
ADS L980
ADS L980/2 (bi-ampable w/ modified C2000 crossover)
ADS L990
ADS L1230 (3 way, 4 driver) (8" woofer) (bi-ampable w/ C2000 crossover)
ADS L1530 (3 way, 4 driver) (10" woofer?) (bi-ampable w/ C2000 crossover)
ADS L2030 (3 way w/ line array mode, 7 driver) (14" woofer) (bi-ampable w/ C2000 crossover)
ADS PB1500 (subwoofer- utilized a C1500 crossover)
ADS PB1500 + 2, L400 (small versions) = SUBSAT2300 (also came w/ F400 stands)
ADS L690 (2 way, 2 driver) (8" woofer)
ADS L990 (3 way, 3 driver) (10" woofer)
ADS L1090 (3 way, 4 driver) (7" woofer)
ADS L1090/2 (3 way, 4 driver) (7" woofer)
L1290 (3 way, 4 driver) (8" woofer) (bi-ampable w/ modified C2000 crossover)
ADS L1290/2 (3 way, 4 driver) (8" woofer) (bi-ampable w/ modified C2000 crossover)
L1590 (3 way, 4 driver) (10" woofer) (bi-ampable w/ modified C2000 crossover)
ADS L1590/2 (3 way, 4 driver) (10" woofer) (bi-ampable w/ modified C2000 crossover)
ADS M9 (3 way, 3 driver) (8" woofer)
ADS M9/90 (3 way, 3 driver) (8" woofer)
ADS M12 (3 way, 4 driver) (8" woofer)
ADS M12/90 (3 way, 4 driver) (8" woofer)
ADS M15 (3 way, 4 driver) (10" woofer)
ADS M15/90 (3 way, 4 driver) (10" woofer)
ADS M20 (3 way, 4 driver) (dual 8" bandpass)
ADS M30 (3 way, 4 driver) (dual 10" bandpass)
ADS C300i (2 way inwall) (5 1/4" woofer)
ADS C300is (2 way inwall) (5 1/4" woofer)
ADS C400i (2 way inwall) (6 1/2" woofer)
ADS C400is (2 way inwall) (6 1/2" woofer)
ADS 750il (3 way inwall) (7" woofer)
ADS SW2 (10" passive in-floor subwoofer)
ADS SW4 (10" passive subwoofer)
ADS SW5 (12" active woofer)
ADS SUB6 (6 1/2" passive subwoofer)
ADS SUBSAT2 (L200e + SUB6)
ADS SUBSAT3 (L300e + SUB6)
ADS SUB10 (10" active bandpass subwoofer)
ADS SUB12 (12" active bandpass subwoofer)
ADS MS1
ADS MS2
ADS MS3
ADS HT400LCR
The ADS models listed below were/are rumored to exist, but after talking with a few members here, these are very well most likely non-existant models. But for the sake of it all, has anyone ever own one of these models listed below, or seen one of 'em, and want to say otherwise? Please let me know. But for now, I'm keeping them off the official list.
The rumored models-
ADS L600, with supposed 7" woofer
ADS 800, supposed 2 or 3 way, supposed 3 or 4 driver
ADS L1430, supposed 3 way, 4 driver
Anyone owning ADS speakers, or anyone who's owned 'em in the past, could you please check the list? If you had a pair that had adifferent ohm rating, please let me know- seems some models started out as 4 ohms, occasionally 6 ohms, but later became 8 ohms.
Also, please verify driver count. The L780s, for instance, I suspect are 3-way, 3-driver, but I would like to be sure. They very well could be 3-way, 4-drivers, like the L810s, L710s, ect...
All help is appreciated.
I Have The L780/2's And They Are 3/3. The 700's You Listed (non 'l') Are 2/3's (DOUBLE WOOF).
Pretty List Of My Favorite Brand -- Thanks For The Effort!
thedelihaus said:
The rumored models-
They don't exist AFAIK.
TDH, my 1975 aDs 710's do not have an L in the model number. I don't think there is any difference between the L710's but there is one person who might know. Soundmotor why was the L left out on some 710 and 810 models? Mine are 4 driver 3 way just like the other 710's. Oh and mine were the early model with foam surrounds but have been upgraded to butyl rubber by Richard So.
The L780s are three way with a single "8" inch woofer. I have the L780/IIs and they are 8 ohm. Also, I've confirmed that L520s came in both 4 and 8 ohm variations. I believe the earlier ones were 4 ohm.
- Pete
Now if we can just get a driver part # rollcall going to match up with the list.
Blue Shadow gave us a good start.
- Pete
Probably better for the dollars and cents forum, but since the L520s are being discussed, I just wanted to write that I have a pair of grills on the e-bay if anyone is interested. If anyone else has some old ADS drives available for sale, I'd be interested in reading more. The parts are getting harder to come by...
Mike
Latest update-
Updated list-
ADS L200
ADS L300c
ADS L200cc
ADS L200e
ADS L400
ADS L400e
ADS L500
ADS L520 (early) (2 way, 2 driver) (8" woofer) 4 ohms
ADS L520 (later) (2 way, 2 driver) (8" woofer) 8 ohms
ADS 700 (2 way, 3 driver)
ADS 710 (3 way, 4 driver) *foam surrounds
ADS L780 (3 way, 3 driver) (8" woofer)
ADS L780/2 (3 way, 3 driver) (8" woofer) 8 ohm
ADS 810 (3-way, 4-driver) 4 ohm
ADS L810/A (3-way, 4-driver) (8" woofers)
ADS L980
ADS L990 (3 way, 3 driver) (10" woofer) 8 ohm
ADS MS1
ADS MS2
ADS MS3
ADS HT400LCR
The highly suspect but still rumored models-
I have the 8Le but can't find any info on them anywhere. Anyone have any info, links, comments? I can tell you they are 2-way, 8 inch woofers/rubber surrounds with I believe are 1" cloth dome tweeters. And of course they sound amazing in that unique clean, accurate, tireless, ADS way. These little guys need sub help if you want deep base but they are very satisfyng on there own.
eThink,
The link's not working for me. ???
EDIT- Never mind, I found it.
Not familar with your stands. But as far as I know, the speakers usually just sit placed on the stands.
thedelihaus said:
Latest update-
Updated list-
ADS L200
ADS L300c
ADS L200cc
ADS L200e
ADS L400
ADS L400e
ADS L500
ADS L980
ADS MS1
ADS MS2
ADS MS3
ADS HT400LCR
I've been working on a pair of ADS 300. No L. I think these are very early examples of the L300 series. They woofers are 206-0320 and have foam surrounds.
As a minor nit pick, L-300s are listed in two places in the list. They show up with the 200 series and again with the 300 series.
- Pete
Okay Pete, with corrections you mentioned, and addition of your model-
Updated list-
ADS L200
ADS L200cc
ADS L200e
ADS 300
ADS L300
ADS L300c
ADS L300cc
ADS L300e
ADS L400
ADS L400e
ADS L500
ADS L980
ADS MS1
ADS MS2
ADS MS3
ADS HT400LCR
The highly suspect but still rumored models- let's call 'em the "Yeti" or "Loch Ness" series...
ADS 800, supposed 2 way, 3 driver
ADS 800, supposed 3 way, 4 driver
ads Speaker Rollcall - Possible Next Step?
It seems that there is a wealth of information and interest at AK in ads speakers to take the "rollcall" thread to the next level.
What about a subfolder on AK dedicated to ads speakers? Within this subfolder, there could be some sticky threads for the ads speakers with pictures of the speakers and, where available, information about specification and original sales prices.
Another thread could be an owner registry, complete with serial #s.
Is this an idea that appeals to other ads fans at AK? :scratch2:
Please share your thoughts on this recommendation.
Thanks!
Steve
