Patfont, any chance you could walk those of us less tech savvy through this modification? Is it just removal of Q401, 402 and 403 and replacement of Q401 with a voltage regulator? If so, any chance you can suggest a regulator for use or pertinent specs? Are there other cuircuit modifications or jumper leads needed to effect this mod?
I did a recap of a unit last winter and this circuit failed on me soon after. Have another currently on the bench with similar problems. Seems these are not very robust parts and have a failure rate or don't like the voltage bump of higher value caps in the power supply.
