Hi all,
I got one of these with a lot of issues. I’ve been reading through this thread, and my first question is: how difficult is it to remove the boards in order to replace the small capacitors and other needed parts?
That is the part that would stop me the most. I’m considering replacing only the power supplies and leaving the rest as it is, using it as a preamp.
The radio only works in mono, though. The phono sounds quite good (it has the hum that I think needs the underneath strapping fix). I’m not concerned about the amplifier side for now.
I have ±15 V and ±11.5 V on the phono board. The voltage across the rails is approximately 51 V, and it should be 44 V, but I guess this is a common problem with the mains voltage increasing from 110 V AC to nearly 120 V.
I hope there is still someone interested in this topic, as it is quite old.
Manel
Edit:
Oh, I just realized that maybe the bottom panel comes out, which would expose the other side of the PCB to allow desoldering.
Second Edit:
I got lucky. I replaced the 1 µF 50 V capacitor (C911 or C912), and now both tuner channels are working.
I lifted one lead on each capacitor to measure them. One measured 1.2 µF, while the other measured almost no capacitance, so the fault was easy to find. I don't know much about radio tuners, but after looking at the schematic, those two capacitors seemed to be associated with the left and right channels.
