The crazy part is this is the second set of monoblocs I had to pick up in the last two days. Here is the other matching set, and they are just about as rare, although far less valued. I wanted a pair of these since they came out in 1980, so this was a thirty five year wait. The specs are insane...
Power : 1x 130W (RMS / 8 Ohm / 20Hz...20Khz / 0,03% THD)
Power bandwidth : 8Hz...100Khz (65W output / 0,03% THD)
THD : 0,006% (1Khz ; rated output)
IMD : < 0,02% at rated output
Frequency response : 1Hz...300Khz (+0 / -3dB)
Damping factor : > 100
Slew rate : 150V / us (8 Ohm, rated output)
Square-wave rise time : 1,2µs (20Khz ; 8 Ohm ; rated output)
Square-wave tilt : < 2% at 20Hz
Total TIM distortion : < 0,007% at rated output
Total Interface IM distortion : < 0,007%
Power supply crosstalk : 0 [?]
S/N ratio : 123dB (IHF-A)
Input impedance : 1,2V for rated output
Input sensitivity : 24kOhm
Dimensions : 38,5 x 7,25 x 32cm
Weight : 10,1kg.
