adnick
Addicted Member
Just finished a plinth build thread for a Russco Studio Pro which went better than expected, so figured I’d press my luck and do a thread on this Fairchild.
The Russco plinth is for a professional model idler drive, it actually belongs to @BillWojo, he specified the size and I did the design build, it can be viewed here:
https://audiokarma.org/forums/index.php?threads/russco-studio-pro-plinth-build.966246/
This Fairchild is a very early model 412 basic #238, wide belt cover, deep body with bottom plate, pop up 45, 45/33 platter.
@Sam Cogley has put together an official Fairchild 412 registry thread, and he outlines the difference between models: https://audiokarma.org/forums/index.php?threads/the-official-fairchild-412-registry-thread.677977/
Fairchild was an amazing individual and and one of his companies produced very high end audio equipment.
In my opinion these tables are extreme bargains still, in its production time the 412 was one of the most expensive turntables available, probably only surpassed by EMTs.
The 412 is the only belt drive turntable, that I’m aware of, which was used as a broadcast table.
Have been looking for one for a long time and this on fit my criteria, needs work and a plinth
Here’s the project:
these are heavy platters with a 3/8” ball bearing in the shaft well and a concaved shaft, the platter is actually filled with plaster
An excellent design implementation; the shaft well is supported and attached to the heavy metal frame.
Thankfully it’s in much better shape than I expected, so it only needed a cleaning, new motor mounts and new belts. @Sam Cogley sent me some new super motor mounts. The motor is completely suspended by the four bright blue mounts:
@Sam Cogley informed me that the yellow wire cover becomes brittle and can vibrate fairly loudly, however this one is very flexible…Motor is very quiet.
Here it is cleaned up a bit, ordered 2 belts and only received one, so that’s next on the list…
Here’s the project:
