AK Design Collaborative - Insignia-Class Economy Speakers (a.k.a Indignia)
Heard them at Rochester AK get together. Very nice indeed.
Congrats to all the AK'ers involved. Now it's available to the masses :tresbon:
Great recognition for AK :banana:
Mine work well with a Scott 222c and a Bob Latino ST-70. Just an incredible speaker for not much cash!!
For mine, I bought 2 small project boards, mounted all components except the big iron core inductor, and soldered everything point to point. I mounted the board to the bottom and the inductor to the rear panel at a right angle. Worked great.
Will using 1/4" plywood and mounting the crossover components to them and then attaching the XO "board" to the bottom of the cabinet cause any problems? I got the 1-1/2" PVC pipe from Lowes this morning and all I need now is some 20-22ga. hookup wire.
I notice that Parts Express sells self-resetting circuit breakers to protect the speakers from being over-driven. Are they any good/useful?
Al
I've done a quick search on this thread but couldn't find this info.
It looks like .38 internal volume is the recommended size for the Insignia? But what is the tuning frequency (or at least the 1.5" port length)?
Al
The 1/4" plywood for the crossover will work just fine, the PCB just makes it a bit easier for those with a soldering iron and not much else.
The circuit breakers probably wouldn't hurt, but I'm not sure they are needed. These arent high power handling party speakers, and under normal conditions, shouldn't be in danger of blowing a tweeter if that's your worry.
I believe it's 37 hz typically, but somewhere in the 37-40hz range has been used to good effect. One of the pairs I built was sealed and it worked very well, as well.
You're probably right; my thought was it would prevent any likelihood of excessive volume damaging the speakers or the crossover.
Al
Is there already a worked out crossover for wall mounted Indignias? Or would it be needed if the speaker is 2"-4" from the wall and front ported?
My "inwallnias" are still a work in process. With the stock crossover, they sound pretty decent. Slightly midbass heavy. Mine are mounted in a wall in a largish sealed enclosure. I don't think I'm going to spend any time adjusting the stock crossover.
The layout for the baffle doesn't reference where the center of the woofer is. If I scale the diagram of the front cutouts, it looks like the center of the woofer cutout is 4.5" from the bottom edge of the baffle and centered across the width. Is this about right?
Al
The Merrill/Scillia modified AR, combined with a AVA Super Pas III pre-amp phono section and DIY Pass F-5. Very nice indeed. These Indignias are well worth the effort and cost.
I run my Indignias with my F5 as well. They've been paired and running every day for over a year and a half. That's like 87 in audio years.
I built a pair of XO's for an ejfud project a while ago and used the back of an old clipboard. I tie wrapped the components to the board, ran the leads to the back and hard wired everything. They aren't that complicated to do.
I have some questions - please help folks.
I am trying to build a set of these ewaves. I am using a GrordonW mix and match magic special 15" woofer. He rconed this specifically for me to do ewaves. It will do 30-well above the 1.2k needed. it has 95/96db spl 1w/1m.
My crossoever, the standard using the 1.5mH and 12uf cap seemed just a bit underwhelming.
GordonW suggested this
Crossover coil: 2mH
Cap: 10uf
Zobel (across woofer): 22uf cap in series with 6.8 ohm 10w resistor
SO, what does increasing the inductor and decreasing the cap do to the sound? More gain? Less Gain? Different frequency response? What?
I am not sue I know what a zobel(filter?) is or does. ANy laymans explainations?
Thanks for the help folks.
BTW - this is going into a 6 cubic foot box, curretnly tuned to 20hz. Made of 3/4" particle board, braced and stuffed with batting.
My material of choice for XO's. :thmbsp: You can get one at Walmart for $.97 and generally get 4 crossovers out of it. Then I mount the leftover clip to the front of a shelf in the shop and use it to hold plans, schematics, etc. while working on the next project.
Al
That sounds fine... just tie the parts to it with tie wraps & wire it point-to-point, and run leads up to the binding posts. I would mount the board with screws using wood shims at the corners and not bind-up the tie wraps on the bottom side. I used aluminum spacers from the same supply house where I got the project boards:
I just noticed that the "Karma Indignia" are on the front page of the Parts Express catalog I just received in the mail. :thmbsp:
