What I would do is run the crossover schematic through a crossover simulator program and find what's ideal for the the impedience and choke, and if it is less than the value that was used (i.e., 8 mfd and 20 mfd), use the closer value/pair that is less than the value used. Similarly, if the program says to use a bigger cap, go to the next size up.Actually I have one more question about the Solen caps: I'm looking at values now, and since there's no 8uF cap, would you use 2x 3.9uF, or the 8.2uF one, or...?
Same for the 21uF one: substitute with 1x 22uF? 18uF + 2.7uF?
Reading up on this online makes one’s (mine at least) head spin, because eventually the discussion goes to ESR and how you have to compensate for it when you use a film cap instead of the original electrolytical one, yada yada.
What Mr Todd hasn't told you is that you will need the impedance curves for your drivers, or at the minimum you need to know their measured impedance at the intended crossover frequency.That’s a great idea.
Should work, does not equal ideal.(4.7+2.7+0.47=7.87uF – should work for the 8uF one?)
Yes, but that's nearly 100% subjective opinion, with little if any empirical data to back it up.but if you think 2x 3.9uF Solen caps would be better
Please step away from the edge, and be careful where you point that thing!At this point I am fully trusting your experience and knowledge.
Sharing your experience will add to the AK knowledge base.I can test both and see if I can hear a difference.
Me too. I remember someone many, many moons ago, went through a crazy long dissertation about why it's better to have as symmetric as possible caps to get a final resultant capacitance. I kinda hazed-out half way through the reading, so I can't remember the crux of the argument.Yes, but that's nearly 100% subjective opinion, with little if any empirical data to back it up.
I'm a big fan of symmetry, and it just seems intuitive that where you're going to parallel 2 or more components they ought to be of equal values.
So does this graph of an 8 ohm 416 tell me where the driver should be crossed or only the impedance value of any point I choose to cross it? For instance, If I choose to cross it at 800 Hz it's going to be 8.2 ohms, 1200 Hz is 9.2 ohms and so forth. Does it tell me the optimum crossover point for best fidelity? I've been wanting to know this for awhile.What Mr Todd hasn't told you is that you will need the impedance curves for your drivers, or at the minimum you need to know their measured impedance at the intended crossover frequency.
This is it, precisely. Those are the values you'd need to enter in a calculator to arrive ~at those crossover points. Before graphic representations were common/popular, companies like JBL for instance provided impedance curves for their drivers in the form of a spreadsheet. The enclosure and tuning will also come into play as they will affect impedance to a varying degree. Put that 416 in a box and that curve will change, put it in a horn, and it'll change even more. Modeling software is your friend.For instance, If I choose to cross it at 800 Hz it's going to be 8.2 ohms, 1200 Hz is 9.2 ohms and so forth.
Alright, I’ll put in the equal value Solens then, and after break in and some weeks of listening and getting used to the sound I’ll switch the caps with the “wild mix” and report if I hear a difference and what kind of.Sharing your experience will add to the AK knowledge base
This sounds off by a far stretch indeed… could the L-pad in the crossover have anything to do with this?But the horn is reported to use 8 mfd and 1.75 mH and this combination this just doesn't work at anywhere near 800 Hz with any reasonable impedience. 17.58 ohms works with 8 mfd, but 4.95 mH and 6.23 ohms requires 22.57 mfd and 1.75 mH.
My thought is that the cap more or less provides the "kneepoint" while the choke affects the slope. So at 8 mfd the kneepoint would be near 800 hz with a 16 ohm load and they simply chose to flatten the slope by using a smaller choke.This sounds off by a far stretch indeed… could the L-pad in the crossover have anything to do with this?
Don't worry about the position of the cap. Speaker crossovers are not DC, in terms of polarity.… and most importantly, now all of a sudden I’m worried about the orientation of the big cap, because I saw there’s a + sign on it that I have no idea what it means? Should I have put it in the other way round?
I know it is/should be a bipolar cap, that’s why the plus was confusing me. Maybe an indication of the direction of how the cap is wound, I know some caps have that.Don't worry about the position of the cap. Speaker crossovers are not DC, in terms of polarity.
That’s smart, but I don’t really have any wire lying around that would be a good lead extension. What are the leads made of, anyway? Sure doesn’t look like copper.What I sometimes do in these situations, is add lead to components.
