Bias can/will affect offset, but:
- The fact that it won't hold steady suggests a component that is not working correctly, rather than a bias issue.
- Setting bias is not difficult, but be aware that a mistake, or a trimmer that goes open while adjusting it, can cause some serious damage. If you decide to adjust bias, first step is just to check it and see if it's way off. Second step is to assure the trimmers are working correctly, and perhaps cleaning them...or ideally, just replacing them.
I would guess that a recap of the power supply and driver boards, along with replacing any known-problem transistors, as well as the differential transistors, would eliminate the wavering offset. If that's too much to take on, you could just replace the differentials with matched (hFE and Vbe) KSC1845s. Unfortunately, the only version of the 1845 available anymore has a lower gain than the originals in your unit. This is not a big problem, but can result in small reduction in output.
All that said, I would not spend much time worrying about your readings...they are not a significant issue.
