RTally
Speaker addict
Greetings to all!
I have a Denon integrated and I noticed on idle or full steam one of the power amplifier heatsinks is noticeably warmer than the other. So I begin by disconnecting all of the wires from the amp, volume to 0, cd as an input and tone defeat ON. Let it cool down for 4h and check the idle current after 10min mark at ON(the amplifier has only this adjustment pot). Left one was a little lower (11mV) but the right one was a little higher (13.5mV). It was very hard to adjust the left one. It drifts too quickly and it's not so stable. So I've only tinkered with that side for now and managed to set it up to 12mV. So I've decided to leave the right one untouched. That way after 60min on time it balanced out to stable L-11.6mV/R-11.5mV. The thing is that now after some testing the right heatsink still heats up more.
So I have a couple of questions on the subject which I'm not sure I understand correctly:
1. Is it normal for the idle current to drift a little constantly (+/-0.1)?
2. The manual states " setup after 2min ON time to 12mV, and after 10min to 12mV ''. So I don't have to bother afterwards if it fluctuates outside 12mV? Or I have to measure again after lets say 60 min ON time? I came to notice that the current stabilizes after about 45min+......
3. Do I have to set up the L and R side to be at 12mV on the 10 min mark or after 60min?
4. The tolerance for setting up is 0.5mV. If I get it set up to L - 11.5mV and R - 12.5mV is that good?
Any advice will be appreciated!
This thread is for people to learn about and report on dc offset (as measured at speaker terminals of amp/receiver).
I suggest that you repost your questions in the Solid State subforum. You will likely get more responses about your idle current setting questions there.
No worries...
