Another update.
(THIS IS BASICALLY JUST A CLEANUP AND STREAMLINE TO THIS AMP)
There are better circuits I would more then likely use instead of the maggie.
Just got done doing the same Maggie 86-01 EL84 amp, Some suggestions!
(it's still using the original basic circuitry here)
The original outputs don't have UL taps, and if yu use some that do the bias
will be off, quite HIGH actually, also I suggest removing the input cap an get
rid of the rediculousy high 6.8 MEG OHM input resistor to something like 270K.
(If going UL or Triode I suggest a 150OHM shared cathode resistor)
I added the 33K and 6.8K feedback resistors to stay at 39K of loop, going to
6.8k is just a bit to much feedback for me here. (ended up at 20k in the end)
(10k feedback resistor is as low as I would go)
I tweaked the front end to better run the 6EU7, with a bit more voltage and
current so it is not quite as starved as it is in it's original form.
I see on the other circuit posted there is no voltage to the top section driver,
and the feedback should not be connected to both the grid of the driver and
the cathode, just the cathode.
I'm posting my updates as schem and the original driver portion, you can see
the caps in the driver cathode section, those are the ones removed to make
the amp run full range and get rid of the EQ.
Since there is no room for choke on the original chassis I beefed up the power
supply with good amount more of capacitance to make the amp a bit cleaner,
should help with the amp now being full range as well.
I upped the cathode bypass cap value to 220uf (it was what I had on hand)
I would have gone with 300-450uf if I had the cap, that should be fine.
I will do the other amp later, removing loop and going to a 12AT7 type driver.
(EDIT) I forgot, I'd added individual 10ohm cathode resistors to each output
before the shared 100ohm so you can measure current in each tube separate.
(shematic updated, I may update later if/when I find more tweaks)
This rebuild was just that, a rebuild, not a full makeover with new circuitry, it
was done to have "stock" setup perform as best it could for what it is and to
evaluate the original circuitry against a totally redesigned version I plan later.
Only large changes are the beefed up power supply, the circuitry is the same
stock circuitry just that EQ stuff is omitted and values "tweaked" a bit there.
