If a moderator would email me I can pass on a PDF copy of the article from the US magazine 'Audio' now defunct for lodging here as a reference. Or, individuals can receive a copy in their inbox after emailing me.
In plan-view a rhombic looks like this <>, it is two Vee antennas joined together, the antenna is loaded with R at the front.
the antenna's pattern is directional <>r ------> like so.
Each equal length element needs to be at least 0.7 lambda long.
You also need to 'orient' your house / its rooms onto a map so that you can point it/them correctly.
If you use 300 ohm TV ribbon to make them you have a double rhombic with about twice the gain. If you make the forward and rear angles narrower the pattern will narrow.
You can build two and spread them so the capture angle is wider, this is VERY useflu for covering a big but distant city's transmitters.
If you have a large house block or a farm-stead, four masts (trees?) can allow you to build an exterior one with very long sides and stacks and stacks of gain. But the build will be a bit more expensive.
I'm not an RF expert nor a ham even, but I've carried a few radios when I was a grunt, and learnt very quickly that the only advantage of whip antennas is their size.
? ......... Having to move around, so as to get through to another set, say with the artillery, is not always desirable for infantry ;-)! think about it.
I do have a whip - a Fanfare FM2G, it is on loan to my BIL's place of business in Yass about 40 miles line of sight away over flattish terrain from Canberra's big telecom tower on a big hill. It's a huge steel shed and yes the whip is up high and outside, it gives reasonable local reception IE < 10 miles range. It was given to me, I would never buy one.
the ABC claim 'adequate' coverage (ie not GOOD) out to and a bit beyond that range on that one flattish part of the target terrain. for the very powerful transmitters for the two national FM networks. Noting that the ABC has a charter that requires them to use very powerful transmitters.
http://www2b.abc.net.au/reception/frequencyfinder/asp/details.asp?transmissionid=894
Stereo is noisy but acceptable to the blokes working off both stations with the whip, and affected by aircraft and traffic on the road outside. I suggested they switch to mono and they now leave the mono button in all the time. It's an old Sanyo cassiever and el cheapo half-inch chipboard boomer spkrs.
Listening out
