cafe latte
Addicted Member
The blank disc method does not work as the tip of the stylus does not touch the groove so it bears no relationship to anti skate forces.![]()
I found that the antiskate force is different on each turntable I have. This also makes the results vary when trying to use the blank disk method for setting AS, So a survey comparing settings on a nominal value if 2 ( supposedly match with a VTF of 2 gram)
What numbers do you get?
It will show what force and relation to VTF designers use, 10-15% can be expected, so 0.2-0.3 gram side force may be typical
Chris
