DSC_8059 by Mark Hardy, on Flickr
DSC_5735 by Mark Hardy, on Flickr
Cornwalls are my fave Klipsch modelMy Dynaudio BM15 Passive speakers are (Discontinued) Professional Studio Monitors, I like them to sound neutral and detailed and not too noisy for close environments around, but they are Near-Field (To really enjoy).
My Klipsch Cornwall speakers can be heard from far longer distance, and are live sounding, but are less neighbour environment friendly at an analytic listening volume.
I use some SP 215-6 Jbl, they have the 2447j horn with 4" titanium diaphragm and 2226 15" woofer, I have a dual 2226 15" sub also run via pa2 into Powersoft M30 and K6. it is remarkably capable system. I never get more than one signal led lit, it is shocking how silent it is, has same 'black velvet' character as my Bryston 4bSST/L7 kit.
Looks like a Lascala bin, or a variation of a Martin. how are you getting down to 20Hz?my 20/20 3-way horns use pro drivers, JBL 2226H woofer, PRV D4500-PhNd & WG4550 Mids and a B&C DE-10 on the tweeters, but with a piano black finish with mahogany accents, they're not quite pro speakers. They're not near field monitors, either, but sitting 2m away, they're like full body headphones: 20 Hz to 20kHz at +/- 3db, time and phase aligned, the sound is enveloping and at 80dB or more, you feel it in your viscera.
it's based on a lascala bin, made from 25mm birch, with corner transitions and doghouse bracing, but with a JBL 2226H woofer. The woofer doghouse is coupled to the upper horn chamber, which has increased in volume by 50% for a total volume of around 8.5 ft. The upper chamber has been sealed and has a rear mounted, alloy 15" passive radiator. It simulated to 28Hz, but boundary loading and a pinch of PEQ go it to 23Hz and 20Hz with assistance from boundary loading.Are those bass ca
well done! take serious effort to find the last bottom Hz. I'm starting to learn about my DBX PA2, I just bought a couple more cables to try biamping the tops but haven't done it yet.it's based on a lascala bin, made from 25mm baltic birch, with corner transitions and doghouse bracing, but with a JBL 2226H woofer. The woofer doghouse is coupled to the upper horn chamber, which has increased in volume by 50% for a total volume of around 8.5 ft. The upper chamber has been sealed and has a rear mounted, alloy 15" passive radiator. It simulated to 28Hz, but boundary loading and a pinch of PEQ go it to 23Hz and 20Hz with assistance from boundary loading.
it's also time and phase aligned:
I always thought that the Sentry 100A went pretty low for the box size and efficiency-sometimes pushing those 6th order vented enclosures can get a bit weird, but I felt EV made a good compromise with the design.I have Yamaha MSP-5 active monitors. They are excellent as computer speakers and are loud enough for mid- and even short far-field listening. I paired them with a Yamaha 10" hifi sub since even a powered speaker with a 5" woofer will be limited.
I also once had EV Sentry 100A passives. They are very very nice speakers but they don't go that low either. I do love that EV Superdome tweeter. @vinyldavid if you blow one (which I heard is difficult) I have several that I may never end up using so ping me.
And I have a pair of JBL L166 which is the home version of one of the 4xxx series monitors - can't remember which one - 4412? (Powered by a really great PA amp, BTW)
Finally I have had by necessity a few PA speakers in various home configs. Overall the monitors are far superior sound, but YMMV.
Conclusion: Pro monitors can be excellent in my experience. But sound reinforcement equipment can be tricky - loud is more important than accurate.
I like where you're going with this. These speakers have been entered into the shopping list. Looked at Bryston and Powersoft for years.I use some SP 215-6 Jbl, they have the 2447j horn with 4" titanium diaphragm and 2226 15" woofer, I have a dual 2226 15" sub also run via pa2 into Powersoft M30 and K6. it is remarkably capable system. I never get more than one signal led lit, it is shocking how silent it is, has same 'black velvet' character as my Bryston 4bSST/L7 kit.
