i already have them i just have yet to clean them and put them back on...Now you need to get the missing badge and A pins, easily found on fleabay.
Glenn
Those are looking great! All of the tough work is done. I got lucky and the black sealer under the woofer lip was pliable enough to reuse.I think you will feel that it's well worth the effort you've put into them. Mine are keepers for sure.
thanks Oblivion! i hope i get lucky when i take these apart .... it would suck to run a screwdriver through a cloth surround now that i did all this work to the cabinets lol
Save yourself money and get the L-Pade along with the caps from PE.
Parts Express Hardware.... (looking at GD70's AR 2a restoration thread for parts list... )
i have a kink in one of the small sides from where i was removing it originally... i plan on splinting it just for precaution...
next; the veneer repair... using a palette knife to spread the glue under all of the loose veneer
ironing the excess glue out
for 2 days i have been fussing with re-adhering the grille cloth... that project is ongoing and tedious...
stretching the fabric as far as it will and gluing it while keeping it straight as possible...
here is a detail of one of the rattier areas of the grille cloth... im piecing in strands of thread to try to blend it in better... that is a project in and of itself and there are several small holes that need similar treatment... there are a couple areas on these grilles where its pretty rough but i have some ideas to try to work that out...
i hope to finish the sanding and oiling on the other cabinet tomorrow night.... might even have the grille covers usable by then as well....
Is that the actual veneer thickness, or some type of laminate like luan?
Yup, rotate them. I did on my restorations and it's recommended across the board on most vintage speakers, especially air suspension woofers with soft spiders.which brings me to another Question:
Should i rotate my woofers 180?
surprises all around... the other caps in the other cabinets are different... one has two caps and the other has 3... ???
im not sure what to think at this point lol
OOooooooooooo KEEP THOSE CAPS!
Those are the "Oil Can" caps. My AR3's have them, and they sound superb.
So for now, pull the pots, open them up and see how the look. If they just need a soaking in vinegar & salt solution and a little sanding to clean up the disks and pot wipers, you're good to go!
Glenn
