AR tonearm parts source
conaway
I've just acquired a basket-case AR turntable (model TT - predecessor to the XA), and need to find a pair of the tonearm pivot screws with conical ends. Does anyone know of a source of these ?
thanks- Jim
the AR TT table is a very early unit, and quite rare. hope you get it up and running. any chance the serial number is on the unit? i'm trying to build a serial number database and don't have many TT numbers.
as for the pivot screws, finding a viable replacement is problematic. as far as i know, it seems the best source for the pivot screws is another donor arm. screws from any XA, TA, XB arm should suffice.
i've looked around for a source of small set screws. haven't found any local (in the US). truthfully, i've never been able to discern exactly what size and thread pitch those AR screws are, so even if i found a source, i wouldn't know what to ask for in terms of size. i'd expect the correct taper of the cone is a factor that would influence bearing friction, too. i assume AR got them from a manufacturer of watch parts. tiny slot head cone point set screws are not in much demand these days.
if you didn't mind ordering from overseas, i found is this place in japan that specializes in micro set screws:
http://www.del-screw.com
they might have a suitable replacement. don't know if they only deal in metric, though. if they didn't have an off the shelf part, they will do custom runs, but i assume there would be a minimum order quantity.
just based on everything else with the AR design, something tells me these are a standard readily available item from somewhere. It really wouldn't surprise me if you could get a bag of 100 of them from McMaster for 10 bucks or so, though you'd need to identify exactly what it is first obviously.
Since I have been working on ARs for a good 30 years I have a lot of parts if anyone has something they need.
Thanks for the replies -
Loquatious - the serial number is 14113 - thanks for the link also. I will check it.
gadget73 - thanks for the tip on mcmaster - didn;t think of them. I'll see what they have -
Sfrost - do you have the pivot pins for the AR tonearm ?
thanks - Jim
thanks jim, FYI your serial number is currently the lowest in the database, meaning it is the earliest production table, so far.
so i can fill in the other details, can you tell me if it is a solid walnut base, or walnut veneer? also what the bottom cover looks like? maybe post some pics? also where the table came from (what state) would help.
thanks - Jim
If SFrost doesn't have them, I should
Thanks again everyone ! I look forward to getting this tt up and running, and will post pics later today.
Loquatious - the base is solid walnut. the bottom cover looks pretty standard to me - just like the xa bottom covers. The t-bar suspended chassis is the squared-off stamped frame, rather than the 1-piece aluminum t-bar, and also has the delrin bushings for the tonearm and platter- of course, both are almost frozen to the platter and tonearm shafts.
I found this unit in Round Rock, TX - got it from the son of the original owner. The son had disassembled the entire unit with the intent of restoring it, but never got around to it. Someone - I assume the original owner - had glued the headshell to the tonearm because the headshell threads were completely stripped. I managed to separate the two, and will be re-wiring the tonearm later this week.
Jim
Here are some pics :
Jim
picture.php
picture.php
picture.php
picture.php
picture.php
thanks for the info and the pics. nice to see details of an early table. i think you scored with that one. its quite a find. glad you're bringing it back. surprised to hear its from texas. seems like all the early models i've documented came from the north east. AR charged extra if you weren't local.
is that an empire cart i see in the headshell?
you didn't mention if you are doing a restoration, or an upgrade. what are you rewiring the tonearm with? AGW 34 magnet wire as original, or something else? like to see pics of the process. think you will retain the stamped T-bar, or swap in a cast unit?
That's an Empire 880 cartridge.
Once I MADE my own pivot screws for an AR. I figured out what the thread was, chucked a screw into a drill, and used a Dremel tool with abrasive disc to turn the little point, then polished the point. Cut off the screw to length with the abrasive disc and because I wasn't careful, the second one flew across the room, never to be seen again. It only took minutes to make another one.
Loquatious - I plan to restore the turntable and keep it as stock as possible, using all the original parts, except for the studs that hold the T-bar. One was missing, so I bought a set from vinyl nirvana and will replace them all. I will use magnet or armature wire to re-wire the tonearm - will probably sacrifice an old computer box fan to get the wire.
GP49 - its an Empire 880p cartridge - how does this compare to a shure m97xe ??
thanks - Jim
The hard part about replacing the cone point screws is not the thread or the cone, it's finding them with slotted heads. If you don't mind having to use an Allen wrench to make adjustments, cone point set screws are not difficult to get.
Jim, the pivot screws are in the mail. Good luck on your rebuild, let me know it you need any other parts.
Steve
yup ! this forum is fantastic - lots of help and knowledge.
I'll post more pics when I;ve made some progress with the turntable.
Jim
Loquatious - from your database of AR turntables, can you tell me what year the model TT AR turntable was made ??
thanks - Jim
