AR XA Tonearm Pivot Screw Source?
Sriskie
Well-Known Member
I just picked up a AR XA-91 that’s missing one of the little pointed set screws that act as the pivot bearing on the tonearm. Anybody have a source for them?
I know this is an old post but I thought I'd write a follow-up for anyone who comes along. There's a listing on eBay for newly-made pairs of "improved AR XA or XB pivot screws" that are made from "17-4 PH (UNS S17400) stainless steel heat treated to H-900 condition." They're being sold by the AR shop (and Thorens) Vinyl Nirvana.
eBay listing is here: https://www.ebay.com/itm/227542023909
If for some reason that link doesn't work or goes away, the Vinyl Nirvana eBay shop is here: vinylnirvana | eBay Stores
I have two AR XA projects that are in less-than-perfect condition. I was going to use the best of the parts from my two XA arms to make one good arm, but now I'm going to rebuild at least one of the arms with new screws instead.
I received a few sets of Dave’s new pivot screws and have already used a set in one restoration. Very nice to have a source for these little parts since no one makes anything that comes close to fitting properly. They may be a hair longer than the original depending on which bearings you use in the spindle pivot.
Good to know, thank you. Does that just mean that the screwdriver-end of the screw may protrude a little? In that case, it seems like it might be an aesthetic thing but not a functional issue.
Or is there a more functional concern regarding them being a bit longer?
Only aesthetic, not a problem with function, actually better since the pivot screw isn’t buried into the boss and hard to turn without the right size screwdriver.
Just chiming in regarding the length. I have fitted them to two STOCK AR XA at this point (one is in the video attached to the listing) and they fit almost flush. These pivot screws were reverse-engineered by the machining company without adding any additional length, however, it IS entirely possible the pivot screws changed in length as AR modified the tables over the years. I do know these do NOT fit the XB-77 as they have a different thread.
Dave
Did you guys have to polish the points on the pivot screws or were they sufficiently polished?
Sorry, I haven't bought a set of these yet so idk. There's a video linked in the eBay description that I watched (<youtu.be/6yRxw_9B0RQ>). I don't recall him saying anything about polishing.
