ar3a -Harman Kardon 430
It's a tad underpowered for the AR3A, but if you don't push it, it should be OK. The 930 works well. If you like your peaks over 100 db, you're really tempting fate.
Ray
I'd still be very careful. Blown output transistors are easy to replace. Finding a replacement for blown tweeters in the AR3A---very difficult.
Ray
I used this combo last summer and it worked fine. The 430 is a great receiver and 4 ohms shouldn't be a problem. As stated, in a normal sized room at normal volumes, you'll be fine.
