AR93 specs and XO points???
kfa888
Addicted Member
I have seen spec sheets on these before. Thinking of an E-wave project speaker and might use these. Anyone got a link to the XO points or pix of the XO?
Thanks in advance.
found them, sorry...
System 3 ways, 4 speaker acoustic suspension system, and a floor type
Use unit For low-pass: 20cm corn type x2
For inside regions: 20cm corn type
For high regions: 3.2cm dome shape
Low-pass play frequency 44Hz -3dB
System Q 0.9
Output sound pressure level 87dB/W/m
Impedance 6ohms (a minimum of 4.5ohms)
Continuation allowable input 125W
Crossover frequency 350Hz, 2kHz
Content volume 50L
Dimensions Width 356x height 778x depth of 273mm
Weight 23kg
