are these any good? Dynaudio Audience 82 floor speakers
Not white van. I've read some nice reviews, but haven't heard a pair myself. Can't say if that's a deal or not.
If a speaker has Dynaudio drivers inside, or a Dynaudio marquee outside, they are worth looking into.
Here are the specs from 2004. Retail was $2500'
Technical Specification I Audience 82
Sensitivity (2.83 V/1 m): 87 dB
Recommended Amp. Power: Small size rooms: - watts
Medium size rooms: >50 watts
Large size rooms: >100 watts
IEC Long Term Power Handling: 300 watts
Impedance, Nominal: 4 ohms
Impedance, (20-200 Hz): 3.9 - 20 ohms
Impedance, (200-20 kHz): 4.1 - 8.0 ohms
Impedance, Phase Shift (20-200 Hz): -61° - +20°
Impedance, Phase Shift (200-20 kHz): -8.8° - +23°
Impedance, HF (200 kHz): 6.5 ohms
Frequency Response (+/- 3 dB): 26 Hz - 21 kHz
Resonance Frequency: 24 Hz
Internal Cabinet Volume: 51 litres
Bass Principle: Bass reflex
Weight: 27.1 kg
Dimensions (W x H x L): 222 x 1057 x 363 mm
Crossover: 3 way.
The crossover is impedance corrected
Crossover Frequencies: 430 and 2000 Hz
Crossover Slope: Woofer 6 dB/oct; Midrange 6 & 12 dB/oct; Tweeter 12
dB/oct
Connection: CE compliant insulated gold binding posts
Recommended Placing: Floor
Remarks: Tweeter: 28 mm soft dome.
Magnetic fluid.
Pure aluminium wire voice coil.
Rear chamber.
Midrange: 15 cm with die cast basket
38 mm pure aluminium wire voice coil.
Cone and dustcap moulded as one piece
Woofers: 2 x 20 cm polypropylene cone
75 mm pure aluminium wire voice coil.
Cabinet: Front baffle 28 mm MDF.
Port plugs and spikes included.
Bitumen damped enclosure.
DYNAUDIO International GmbH
Ohepark 2
21224 Rosengarten
Germany
Phone +49 (0)4108 - 4180 - 0
Fax +49 (0)4108 - 4180 - 10
E-Mail info@dynaudio.de
USt-Id. Nr. DE 114 960 879
Tostedt HRB 3346 • GF: W. Ehrenholz
I have heard them at a shop local to me. I like them, but they can sound a touch bright depending on the rest of the components.
I'm not sure what the CL poster was going on about, with his comments about less than full audio spectrum. Speakers that play sub-30Hz don't exactly grow on trees. Doing it this well is another story altogether. If I was looking for a pair of floorstanders, I would think very hard about those. The price seems about right.
