.No, I found this University Driver instead and I'm going to turn it all into a "three-way" system. Paul C has set me up with a crossover schematic, and I'm going to build one of the classic EV corner cabinet styles to hold the big EV driver, with a small extra cab on top for the University Coaxial. I was originally going to build a folded horn design, but then I found all the EV lit on their cabinets thanks to member mhardy6647.Captain Scary said:All of the info I found never mentioned Argos
making speakers that size,very nice with the EV.
Did you ever put a TW-35 in it?
If your still looking for one I have one 16 Ohm and one 8 Ohm,
no X-overs though.
Your welcome to either one if you are interested ?
Cheers,
Barry
mhardy6647 said:FWIW, here's a peek at the ones I had for a bit...
EDIT: Ooops, the tweeters were Jensen AlNiCo cones... I forgot.
The "vinyl" on mine is thick, heavy, and textured. Never seen any quite like it - very durable stuff.mhardy6647 said:The other little detail I forgot, but has been mentioned by others, was that the cabinets were in fact plywood, covered with vinyl.
duh.
Lo and behold, guess what turned up in deep dark forgotten storage in the attic at our Church? Argos Line arrays! Match your description exactly, Celt. :yes:Celt said:Back in the early 70's, our church sanctuary had a pair of Argos line arrays on each side of the organ pipes for the PA. Each had six 8" drivers with a 70-15k Hz response. Boxes were walnut vinyl veneer over plywood and cane grilles. They did their job well.
w00t!ozmoid said:Lo and behold, guess what turned up in deep dark forgotten storage in the attic at our Church? Argos Line arrays! Match your description exactly, Celt. :yes:
My failing memory was right!
